Results 1 to 14 of 14
    May 2012
    Good day mga sir, gusto ko lang po malaman kung possible po ba na i-convert ang corolla GLI ko po from power steering to manual? twice na po kasi akong nasiraan ng power steering at sobrang gastos po talaga, so I am thinking if it's possible po yung ganun? as I have research rack and pinion po ung type ng power steering ng GLI corolla... I really need some advice... Thanks in advance po...
    sir ask ko lang,ano naging sira ng power steering mo? yung sakin kasi ang bigat nung manibela kasi may leak siya, di ko pa napapagawa eh.
    May 2012
    Quote Originally Posted by d'flash View Post
    ang sabi kasi sa akin nung mekaniko sir papalitan daw mismo yung power steering kit ng buo.. kasi nung nag park ako last week daming tagas sa may tapat ng rack and pinion... nung last kasi kinalas na rin yun at maraming pinalitang pyesa kaso sabi saken masasayang daw lahat yun kasi papalitan na ng buo.. Im not that familiar with power steering parts so i was thinking kung ok lang yung naiisip kong i-convert na lang muna sya sa manual steering.
    Aug 2012
    Nasa inyo po iyan baka po manibago kayo sa handling ng manual steering, mare-repair naman po yang powersteering ask your trusted mechanic mareremedyuhan po iyan.
    May 2012
    yes sir naisip ko rin po yun.. kaso sir it will take time for me to produce 10k para po mapaayos yung power steering.. anyways thank you sir..
    Quote Originally Posted by pong_pong View Post
    perhaps what you need is another, more knowledgeable mechanic..
    i once had my power steering (non-toyota, sir) unit fixed because of leak. sabi sakin, it's just the hose. and he recommended i use original japan, dahil local replacement hoses do not last long.. sinundan ko.. ayun, 1 year na, ok pa naman.
    of course, nahimatay ako sa presyo ng hose lamang, but i think it was worth it.
    Aug 2011
    Sir ang pagaayos ng power steering should be with the experts or yung mga mekaniko or shops that specialize in power steering...buti yung sa iyo nasisira lang...kasi naikwento sa akin ng mekaniko ko dati na meron naaksidente sa skyway na di makabig yung manibela kasi di maganda pagkakabit ng power steering niya. If I remember it right yung mga bosch automotive shops specializes on this. Maginquire ka rin sa ibang mga shops or sa mga kakilala mo baka meron silang alam na shop that specializes on this....HTH
    May 2012
    Thank you so much po sa mga inputs .. I am learning lots from all of you mga sir.. aalamin ko po muna kung saan po talaga yung leak so I can do the appropriate action.. salamat po sa inyo...
    kung gusto mo hanap ka ng surplus, then benta mo na, bili ka na lang ng iba kung sakit na ng ulo.
    Nov 2012
    Sir naku wag mo ng pangarapin mag manual a.k.a pawis steering, Sakin XL nung una hirap na hirap ako and nagiisip na i-convert na sa power steering pero yung naghohold sakin is luma na yung sasakyan and baka maging complikado yung mga bagay bagay kya as is nalang , Nasanay din naman ako nung nagtagal. pero xempre hirap pdin sa mga bwelta compared sa power steering haha walang ka hassle hassle
    Feb 2012
    Sir baka yung nabili mong power steering kit ay replacement lng yung tig 1,500php good for 1month lng po iyon na experience ko na po yan. last sept. 8 ,2012 then bumigay uli Oct.5 nag hanap ako ng trusted mechanic pina bili nya sa akin yung original na power steering kit. worth 4,300 php then labor is 2,600 di ka aabutin ng 10T till now ok na po ang power steering ko napaka smooth.
GLI power steering to manual conversion?
