Results 1 to 16 of 16
    mga sir, mejo may prob ang clutch ko, naka park ng overnight yung car ko, at tuwing gagamitin ko siya nang umaga, malambot pa ang clutch niya,pero kapag lagay sa first gear tapos release the clutch pedal mejo parang palyado/ ma vibrate yung car.
    pero kapag matagal tagal na gamit kotche, tumitigas na ng konti yung clutch at nawawala na yung parang palya na takbo kapag bumibitaw ng clutch.
    natry ko na yung full stop, then ilagay sa 4th o 5th gear, tapos slowly release the clutch, ok naman mga sir. ngsstall yung makina, so alam ko na ok pa naman yung clutch lining ko.
    sliding na ba clutch ko mga sir?
    dalawang mekaniko na natanongan ko, at pareho sila nagsasabi na clutch lining daw yun, or pressure plate lang.
    mejo tight ang budget ko eh, kaya sana yung may sira na parts lang muna papalitan ko.
    ano kaya promlem nito sir?kulang pa kasi budget ko para sa clutch disk, pressure plate, release bearing na isang bagsakan.
    at safe pa ba gamitin kotche ko? parang di ko pa naman na fifeel na ngsslide yung clutch ko. pwera lang dun sa palya/vibrate sa makina, pero bihira naman mangyari at di naman malakas yung palya/vibration. di ko lang sure kung sign naba to nang sliding clutch.
    salamat po sa mga magrereply..
    the car po pala is toyota corolla big body gli. hydraulic na po yung clutch ko..
    Chief j_dipad,
    Though your clutch lining might still be ok (or in a verge of a major wear), most likely you already have a worn-out pressure plate. Is it still safe to use if it causes your car to vibrate? Sad to say but its a big no, it will definitely harm your transmission. Though costly, it'll be more cheaper if you'll replace the lining, pressure plate, bearing and transmission oil at the same time.
    Thanks
    thank you sir sa reply.. sign na ba tlga na manipis n lining ko? or pressure plate lang?
    Jan 2011
    Malaman mo talaga manipis na yung clutch lining sir kung maibaba yung tranny mo, better to replace na lahat para isang gastos na lang sa labor, kung pa isa isa parts ka lang another labor ka ulit, pwede din na replacement parts pero siyempre mag ready ka din after 1-2 years bago ulit masira, compare sa mga OEM parts, 3-5 years bago ka magreplace
    Quote Originally Posted by KIANTOT View Post
    ganun lang ba talaga kadali sir ang replacement parts? sa na aalala ko kasi siguro mga 10yrs na ako di nagpa baba ng transmission ko. tight kasi budget ko ngayon.daming gastusin.
    sana mejo tumagal pa transmission ko kahit 1 more month, para makaipon ako at sundin ko mga payo niyo mga idol na palit na lahat. isang bagsakan nalang.
    hindi naman ako clutch driver eh.sanay ako na di nakababad sa clutch paa ko.
    Jan 2011
    Yung estimate ko na 1-2years sa replacement at 3-5years sa OEM everyday use mag 90-120kms a day city driving, iba pa yung mga out of town na byahe,, kung hindi naman ganun ang takbo mo everyday sa OEM pwede kahit mga 10years,sa replacement clutch lining na experience ko dati wala pa 1 year, sliding na, hindi maganda yung iba madali masunog kaya matigas na yung lining tendency mag slide agad kahit makapal pa
    ah.ok sir. salamat po sa reply niyo. mostly city driving lang naman ako. school bahay lang. more or less mga 8km per day lang ang byahe ko kaya siguro naman matagal tagal naman bago masiri kahit replacement parts lang.
    any comment po sir sa pag pa clutch rebond? meron kasi akong friend na naka clutch bond lang, ok naman daw. matagal niya na din nagagamit.
    Apr 2010
    1500 yung labor ko the last time. So thats just right.
    Peace out!
    Oct 2013
    Quote Originally Posted by theshepherd View Post
    Peace out!
    haha thanks men! ok nadin pala 1,800 kasama na palit ng valve ng oil seal kasi binaba transmission ko.
    Oct 2013
    bakit kaya ganun after ko magpapalit ng sa clutch lining
    everytime na iaaccelerate ko yung takbo ko, parang may kumakaliskis na tunog? pinapaltan din nila yung brake pads. pero ganun padin.
    Jul 2012
    hi.
    we have a toyota revo 2000 glx automatic (115,180 kms). feeling namin, parang hindi na nag shi-shift ng gear. parang up to from 2nd or 3rd na lang ata. kaya pina check namin kanina sa isa'ng car repair shop, ang sabi clutch lining daw. also, baka kelangan din daw palitan yung shift solenoids. pwede ba malaman kung ano2 mga parts ang need palitan para isa'ng babaanan na lang ng transmission? aside from original toyota parts, ano yung recommend other brand na reliable? do you have any idea how much would be the labor cost?
    thanks in advance.
clutch lining problem?
