Results 1 to 10 of 10
    Jun 2004
    hi mga peeps,
    last long weekend on our way to pagudpud. napansin namin na hindi na umiikot ang trip meter and odometer ng corolla gli namin. can anyone recommend a reliable repair person who can repair it. thanks
    mintoy
    Aug 2006
    Quote Originally Posted by mintoy View Post
    hi mga peeps,
    mintoy
    Probably just the faulty odometer cable going to the transmission. Any reputable mechanic can replace and fix it for you.
    Your location is also needed for others to reply and recommend a mechanic for you just in case.
    May 2004
    madali lang yan probably speedometer cable lang yan naputol... Pakabit mo agad para hindi ka mawala sa schedule ng maintenance mo..
    Sep 2004
    Either the speedo cable or the Vehicle Speed Sensor.
    Pero teka, trip meter and odometer lang ba ang sira? Gumagana ba ang speedometer? Pag gumagana pa rin kasi, baka may sirang gear lang sa trip meter, hindi kumkagat.
    Pag putol ang speedo cable or sira na yung speed sensor, hindi rin gagana ang speedometer.
    Jun 2004
    Quote Originally Posted by Galactus View Post
    i eleminated the possible broken speedometer cable cuz the speedometer works well. i tried pressing the reset button several times hoping it could just be a loose connection of the gears but to success.
    Aug 2006
    If that's an analog odometer, it is possible that the gear got misaligned.
    Sep 2013
    Quote Originally Posted by Mile2 View Post
    Sir any recommended electrian para maayos ung cable may ganyang problema din ako sa car ko? Thanks
    Quote Originally Posted by Madmaxx143 View Post
    Up for dis 1, ung akin naman po ung odometer lang d gumagana, speed0meter tripmeter ok naman, ung gear lang pob sira n0n? Chka pan0 po mg2wa un? Tnx tsikot. Toyota lovelife p0 akin, 98 m0del
    Apr 2005
    J6 Banawe.
    J6 or Jemsons. Php2100 po yata yung repair ng odo sa Patrol. Magulo kasi sa J6 kaya po yung assistant ni Jemson ang inutusan namin. Tapos pina upgrade ko na din to LED backlighting kay jemson plus gauge cleaning service.
trip meter and odometer repair guy needed
