Results 1 to 8 of 8
    Feb 2013
    Hi everyone, I have a Toyota Vios vvt-i, and whenever I'm driving it, its like the engine is going wild. It consumes a lot of gasoline compared before. I already changed the sensors and cleaned the what they call "serbo" but the problem is still there. If you have some ideas about my problem, I hope you can help me. Thanks and have a good day.
    Quote Originally Posted by louiiejt View Post
    bakit po di mo na lang pa check sa CASA? para magawan ng recommendation. What sensor did you changed? O2 sensor?
    Ilan na mileage nung car? Have you cleaned the air filter, MAF and Throttle Body already?
    Jan 2009
    What's the model and mileage of your vios? Di ba flooded? Have it diagnosed at casa then pagawa mo sa reputable shop sa labas.. May kilala ako toyota machanic. Just pm me baka makatulong.
    Sep 2006
    Sir Meron 3 screw dyan sa gilid ng throttle body yun Meron hose na 2 yun kasi yun sa idle or menor ng 1st gen na vios minsan kasi madumi yan kaya malakas yun menor. Kung 2nd gen naman try niyo alisin yun battery terminal pag mag reset yun computer box.
    Dec 2012
    sir may i ask if your engine problem was already solved? Kasi same po tayo ng problem. Wait ko po your feedback, thanks.
    Oct 2011
    Sir pa update lang kung ano na findings sa casa/ almost 1 month na pala ito.
    Apr 2014
    Sir same problem din po dito.ask ko lng po kung nasolve na ung problem mo po. 2010 toyota vios 1.3e. sana my makatulong saamin. tnx.
Toyota Vios - Engine Problem
