Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 139
    Sep 2004
    #81
    Has anyone tried these from Ziebart?
    1) Diamond Gloss
    2) Undercoat Sound Barrier
    regarding diamond gloss, may nakausap akong fortuner owner na masyado daw manipis ang coat ng paint ng fortuner a staff from ziebart told her daw after her unit undergone diamond gloss treatment.
    May 2004
    #82
    mga bro, may nagpakabit na ba ng roof rack sa inyo? malamang kailanganin ko eh. anong klase/brand pinakabit nyo? ok/bagay ba? TIA
    #83
    bumili ako ng car cover for SUV hirap kasi mag linis ng roof. cover ko nalang sya. cost me 2000 for that. ok naman fit na fit sa fortuner.
    #84
    Quote Originally Posted by vicoyski
    Someone here once posted that if you run your vehicle below 1500rpm for over 2-3 minutes, you wont' have to idle your engine for 1 or 2 minutes before turning the ignition switch off. Actually, that's what I do. I make sure I don't go over 1500rpm while looking for a parking slot. If the parking slot search takes longer, I won't use my turbo timer anymore.
    So hindi pala sa speed yon, sa RPM. So ill just make sure that I will not exceed 1500 RPM a minute or 2 before my destination. Tnx a lot.
    RE: paint protection, I had it done at the casa during my 1000 PMS.
    #85
    Quote Originally Posted by bilog
    bilog,
    does this mean ninipis ang paint coating bago i-apply ang Dimond Gloss? Or talagang manipis na ang coating before application?
    attynorby
    "Had mine DG, Php8,200.00. "
    attynorby, any comments po tunkol dito sa sinabi ni bilog? Will DG prevent minor scratches (say from plants, etc.)? Nilagyan din ba ang loob (inner side)ng mga pinto and arches?
    Anybody: on the Underbody Sound Barrier from Ziebart? Thanks sa mga comments and suggestions....
    Sep 2004
    #86
    she said the paint of the fortuner is coated thin. i do not know if this is true though. malalaman din natin yan in time.
    #87
    with regards to the turbo of the fortuner, iba ang design nito, it has variable vanes to keep turbo lag at a minimum. so even if the rpm is low it still spins, unlike the turbo of older designed engines that it usually spools up in the 2500 up region. so even if slow driving or low rpm ka there is a chance na the turbo is spinning in the fortuner. better to have a timer installed.
    #88
    oo tama sila sobra nipis ng coat ng fortuner. ksi nabangga ko lang yung ng konti yun pinto sa wall. tangal na yung paint nya. lumabas na yung white color nya.
    ask ko lang ilang hours yung procedure ng pag DG., wala bang mura dyan?
    Aug 2005
    #89
    Quote Originally Posted by konde
    nagpalagay me pero bihira ko rin nagagamit , aerorack brand 3,500 lang sa goldrich banawe, may carryboy din pero mahal nasa 6,000-8,000 ata and parang mas konti bakal yun sa carryboy, after installing kailangan ka pa kumuha ng permit sa LTO yan, tawag nila TOP LOAD, minimal fees lang, ang disadvantage lang sa roofrack ko (dunno with other brand) is when you reach the speed between 120-130kph,may vibration kang maririnig galing sa roof :down: nakakapagtaka nga eh kc pag over 130kph mawawala yun vibration, basta may vibration lang bet 120-130kph
    May 2004
    #90
    fortuner 13::: pa-post naman ng pic sir. tnx
    #91
    mura ba talaga sa goldrich sa banawe i want to buy a mud guard. bka may info ka about that
    Mar 2005
    #92
    Quote Originally Posted by letranboy
    Not necessarily... I inquired about the OEM Turbo Timer there. It cost P4.5T daw. I got mine for P1.8T from Miggyboy. Wala nga lang installation.
    Jul 2005
    #93
    anyone who knows where i can get this?
    toyota sequoia/tundra 17" factory mags. please PM me your leads. thanks
    #94
    Don't take my word for it but I think I saw a set in one of those wheel stores along Tomas Mapua recently.
    Sorry, MB wheels kasi ang pakay ko nun kaya I wasn't paying much attention.
    You can also try US based auto recyclers if they have these in stock.
    Feb 2003
    #95
    Pre, don't forget to install an effective security system like a GSM car alarm. The risk is too high for these Fortuners to be taken away by carjackers nowadays.
    #96
    nag tanong nga ako ng GSM medyo may kamahalan i think its 16K free installation. sayang hindi sila accept credit card, kuha sana ako eh.
    May 2004
    #97
    san ka sir nakabili? di ba nakakagasgas?TIA
    May 2005
    #98
    Best bet for a car cover is an all weather one, medyo mahal but at least you can use it any where not like the others which are like paper (only used indoors) and degrades in time.
    Mostly available in all Car accessories shops and Hardware shops sa malls.
    Nov 2003
    #99
    Finally, I installed OME shocks to my fortuner this morning. As expected the ride is noticeably softer. I'll give it a few more days and kilometers to set in before I report the results.
    #100
    nakuha ko sya sa toyota narin cost me 2k
Fortuner Accessories
