Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jul 2003
    bakit naka light yung airbag led light kahit naka andar na makina? hindi mag o off?
    Quote Originally Posted by acenie View Post
    There's an SRS Fault. Most common is the seat occupancy sensor.
    Jul 2003
    saan banda ko echeck sir?
    The SRS is an electronic system, sir. Have the fault code extracted & diagnosed professionally. Try checking the harness under the front seats.
    Aug 2014
    Kadalasan Baka sira yung spiral cable. Pa check mo sir
    Sent from my SM-G950U using Tapatalk
    Jul 2003
    Quote Originally Posted by timming_gear View Post
    saan banda yun sir?
    ok sir thanx
    Jan 2008
    saan banda yun sir?
    ok sir thanx
    Yung clock spring sa manibela.. yan yung assembly na umiikot para sa connection ng horn. Airbag. At steering wheel controls
    Jul 2003
    ah ok sir echeck ko doon
    Jan 2008
    mahirap i check yan sir.. you need to remove the airbag.. you will need a torx screw! pero bago mo tanggalin, you need to verify na yung airbag talaga may problem..
    sa auto ko dati may separate diagnostic plug yung airbag tapos may 2 pins ka na lalagyan ng jumper wire then mag blink yung airbag light according to the error.. may number of flashes that correspond to a specific error..
    was it toyota who recently announced a spiral cable recall?
    Aug 2014
    Sa Fortuner at innova 1st Gen 2005-2008 ata dok.
    Jul 2003
    lahat ng CASA ng toyota pwede e pacheck sir?
    Aug 2014
    Yep alam ko my recall issue talaga ang imv toyota platform sa airbag
    https://www.autoindustriya.com/auto-...bag-cable.html
    Aug 2017
    Including Gen1 Altis. Toyota Q Ave replaced mine FOC
    I've never seen an untouched clockspring cause SRS faults. Most modules are by the eBrake. Those that had flooding damage that module would see that light on, too.
    Its a faulty clockspring under the horn.
    Sent from my P01MA using Tapatalk
    You've had this happen, sir? Takata?
    Yup. On the UM Sorento it occurs between 50-60k kms.
    Underneath the car horn in newer cars is a ribbon cable, not unlike the ribbon cables in a desktop computer. It carries the signals from steering wheel controls for the radio, the MID and of course the horn. Its wound up underneath so it literally looks like a spring used in old clocks and wind up toys. The wires are very thin and difficult to find the break so the only option is to replace the whole clockspring.
    Good to know. Thanks. Never seen such. With euros, it's common to see the seat occupancy sensor fail.
    Jan 2019
    Faulty clockspring under the horn.
Fortuner 2006 AT Diesel " Airbag Lights steady ON"
