Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Jul 2003
    bakit naka light yung airbag led light kahit naka andar na makina? hindi mag o off?
    Quote Originally Posted by acenie View Post
    There's an SRS Fault. Most common is the seat occupancy sensor.
    Jul 2003
    saan banda ko echeck sir?
    The SRS is an electronic system, sir. Have the fault code extracted & diagnosed professionally. Try checking the harness under the front seats.
    Aug 2014
    Kadalasan Baka sira yung spiral cable. Pa check mo sir
    Sent from my SM-G950U using Tapatalk
    Jul 2003
    Quote Originally Posted by timming_gear View Post
    saan banda yun sir?
    ok sir thanx
    Jan 2008
    saan banda yun sir?
    ok sir thanx
    Yung clock spring sa manibela.. yan yung assembly na umiikot para sa connection ng horn. Airbag. At steering wheel controls
    Jul 2003
    ah ok sir echeck ko doon
    I've never seen an untouched clockspring cause SRS faults. Most modules are by the eBrake. Those that had flooding damage that module would see that light on, too.
    Its a faulty clockspring under the horn.
    Sent from my P01MA using Tapatalk
Fortuner 2006 AT Diesel " Airbag Lights steady ON"
