Results 21 to 40 of 43
    Sep 2016
    #21
    up lang.hehe
    poor lubrication...
    #23
    Quote Originally Posted by dhenz76 View Post
    sir ano po mga posibling dahilan? salamat
    ignition timing is too advanced. years ago, this was easy to check. a simple timing light and a knowledgeable mechanic was all that was needed. is it possible, ganito pa rin ngayon mag-check?
    if your ignition timing is ok, try the fuel. your fuel may be of poor (low octane) quality. when your fuel is near empty, gas up with higher octane (95 or higher) gas, and see if the sound disappears.
    Sep 2016
    #24
    poor lubrication? siguro nga sir kasi muntik ng natuyuan engine oil last 2015, nasa abroad kasi ako at gamit ni bayaw.
    timing advance? ano po posibling dahilan sir? sa monday balak ko ipatingin sa suking mekaniko, priority ko ay ipalinis din talaga ang engine oil lines. paano itesk ang high tension wire, coil pack at spark plugs? plugs ko naman bagong palit last october 2016. ipinalit ko yung nasa manual naman na ngk brand
    Sep 2016
    #25
    gamit ko nga pala 95 ron talaga, posibling maluwang na timing chain? hindi pa napalitan simula noon?hehe odo reading ay 206k na rin pala :-)
    Sep 2016
    #26
    isama na rin valve clearance adjustment
    #27
    May valve lash adjustment ba ang 2005 altis? 4a-fe tama ba?
    As for sludge buksan ninyo po yun oil filler cap. See kun may namuo na langis sa ilalim ng cap.
    As for the sound you really should bring it to a mechanic mahirap mang hula especially dinedescribe mo lang yun noise. Ok kun mapakinggan ng actual
    Sep 2016
    #28
    3zz-fe sir. salamat sa lahat ng input nyo. sana hindi gagastos ng malaki
    Sep 2016
    #29
    up ko lang mga sir baka me input pa po. salamat
    you said you changed the engine oil last oct 2016. was that by chance fs?
    Sep 2016
    #31
    sorry sur noob, ano po yung fs? salamat
    Sep 2016
    #32
    sorry sir noob, ano po yung fs? salamat
    #33
    fully synthetic
    #34
    btw yun iba ginagawa, mumog daw ng delo for a 1k km, tapos palit fully synthetic na.
    Sep 2016
    #35
    Try to google engine decarbonizing. Meron yata na gumagawa nito sa banawe carbase if im not mistaken.
    Sep 2016
    #36
    sir semi synthetic shell X7 gamit ko last change oil. patingin ko na lang sa suking mekaniko bukas. salamat sa tulong nyo
    how long do you plan to keep that oil?
    Sep 2016
    #38
    sir next week mapalitan na rin yan kasi patingnan ko oil lines at valve clearance kasi meron nga pala lagitik sa valve tappets ba yun?
    Sep 2016
    #39
    paano po mag tsek ng coil pack mga sir, meron ako nakita sa youtube pero hindi ko natapos. paano ma check using multitester ang coil packs at plugs kasi pinaandar ko kagabi at nilayo ko coil packs, meron dalawa nag-iba sound ng engine. palatandaan daw ito na baka me problema ang coils or plugs? tama po ba?magandang umaga at salamat
    Sep 2016
    #40
    good day tsikoteers. nadala ko na sa suking mekaniko. so far positive ang ginawa nya, me nakita maliit na leak sa exhaust system at palit na rin valve cover gasket kasi nagkalangis isang plug. ayos ang resulta ng ginawa.ok na hatak ng makina ulit :-)
engine noise
