Results 1 to 10 of 12
- Mar 2007
- 57
November 4th, 2012 02:14 PM #1Guys help on this problem of mine. got this unusual sound tick...tick..near aircon and alternator area no pattern of sound..
What I did was:
1. I replace the idler bearings with part # 6301du ball bearings 2pcs two idlers
2. Pulley Bearing of aircon with part # 35BD4820DUM6
Not replaced is the:
Tensioner bearing and alternator bearing
Test with no load, i mean removed the belt and start the engine and there is no tick..tick.. sound.....so confirmed that its on the load side not in the engine where the unusual sound is.
[B]Question Guys is it possible to replace the alternator bearing?[/B]
- Jan 2011
- 193
November 5th, 2012 09:36 AM #3You might want to really examine the belt.
If there is a slight cut (or damage) on the side facing the pulleys, you will get a "rapping" sound. But before "rapping" begins, you might get a "ticking" sound.
Ciao!
Uncle Nick.
- Mar 2007
- 57
November 5th, 2012 08:15 PM #4
- Mar 2007
- 57
November 5th, 2012 08:17 PM #5
November 5th, 2012 09:49 PM #6
- Oct 2008
- 267
November 6th, 2012 02:21 AM #7
November 6th, 2012 09:17 AM #8
November 6th, 2012 09:52 AM #9
sir may tensioner shock and lever arm po ba ang ride nyo? if yes dyan po ppwedeng mangaling ang tic tic sound...
did you recently replaced your fan belt? if yes... matigas o makunat pa fan belt nyo... sa tensioner shock and lever arm nangagaling ang sound... just wait for about 500 kms... mawawala na yan tic tic sound na yan...
November 7th, 2012 08:52 PM #10
eh normal lang naman sa innova yun eh, yung saken ganun eh, 2011 toyota innova G, auto climate control AC ko, basta i on ko ang AC may tic tic agad.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
