Results 1 to 18 of 18
    Guys check this out. My latest project on my beloved Innova
    [ame="http://www.youtube.com/watch?v=67Hnh9WGanY"]http://www.youtube.com/watch?v=67Hnh9WGanY[/ame]
    Dec 2008
    Quote Originally Posted by Ginnova View Post
    sir ok yan ah how it was done pa share naman
    Here is my wild guess...
    The wire connected to power lock actuator rerouted to power window master switch...
    very nice idea eto...
    what you have to do with door is lock/unlock manually.
    disadvantage of this is mas madaling ma wear-out ang 4 power window motor
    mas mura power lock actuator...
    unless otherwise dalawa ang RC, one for windows and one for doors
    i think may isang provision ang RC for rear door lock that can be use as master door lock...
    wow talaga...galing.
    sir Ginnova, auto engine start(AC ON) naman para complete na....hehehe
  4. #4
    I doubt if that's stock TVSS working the windows. Multiple presses eh (3x) for close and open. Ano yan sir Ginnova, Autopage ba? Nice project sir.
    Same technology nung sa Ford Focus.
    Ganyan din. Remote controlled power windows.
    Nice to have, I just don't get the point of having those. No offense meant, though.
    Actually my first goal is to automate all 4 windows to go all the way up or down with a single push/pull of the button. this is just an added feature.
    Na-iinis kasi ako kapag galing tool booth , kailangan pa steady i-pull yung power window button para magfully close yung window ( for Innnova ). No auto roll-up feature.
    Pag nagpapark ako sa bahay especially at night , kailangan ko ibaba yung both front windows to have good visibily. kadalasan nakakalimutan ko isara
    yung windows sa passenger side at nakikita ko lang kapag nakababa na ako sa kotse. bad thing is need to insert key to close the window.
    Also my ride is always parked under the sun at most of the time need to
    open all 4 windows para sumingaw ang init. so i decided to built this project. Of course , dagdag pogi points din.
    Quote Originally Posted by paolorenzo View Post
    I used the stock TVSS module ( to save on cost ) to control the window. pwede gumamit ng ibang alarm.
    Quote Originally Posted by xda2jojo View Post
    I used the stock alarm to control the window and some logic and switching circuits to control the windows up /down. this is still my protoype. some changes will be implemented based feedbacks. I might change the setting to 2 press only to activate it.
    Jun 2006
    so everytime you unlock your door lock, bubukas ang bintana?
    Quote Originally Posted by shibby75 View Post
    No, need to press 3 times para magbukas. single press will be ignored by the auto roll up/down system.
    Just be sure that you`re parked in a safe spot.
    Opening all your windows without you inside the car can endanger the things placed inside your vehicle ...
    Sep 2009
    Astig... I think BMW or Audi also has this feature, you have to press the lock & unlock button on the key fob at the same time to make the windows go down...
    This is a very useful feature when you have to move your car when flood water is already past the door sills, so water can't go in your interior
    yup bmw has those and range rovers even sunroof will open after the windows, but you have to press twice and hold instead, not sure about audi. it's only useful to me if i'm parked under the sun. besides that i don't really use it.
    Feb 2007
    very nice project.very useful po ito when you are parked under the sun.idol sir paano po gawin?
    Need to install module to control the windows.
    di ba delikado baka merong accidental na maipit ang windows during remote operation.
    Feb 2011
    SIR,
    PANO MO GINAWA YAN? MAY DEVICE KA PA BA NILAGAY? TURO MO NAMAN SKIN SIR KUNG PANO YAN AT SAN NAKAKABILI NG DEVICE NIA KUNG MERON MAN. EMAIL MO AKO D2 "valdez.aldrin*yahoo.com.ph"
    thanks po
    meron ako control module which I connected to the power window motor.
Remote Controlled Power Windows
