Results 1 to 6 of 6
    Dec 2009
    hi mga bossing, my car is corolla94 gli..tanong lang po kung ok naman ilaw sa dashboard pag naka-on yung key, pero ayaw mag start khit crank possible ba na defective computer box ko? help po. thanks
    Mar 2004
    Quote Originally Posted by j0nSKI View Post
    Jonski,
    maraming dahilan kung bakit ayaw mag start ang sasakyan mo pag on mio ng ignition switch.
    Una diyan, baka umido na ang connection mo sa ignition key, or baka mahina na battery mo, or baka me diperensya na starter / solenoid ng sasakyan mo.
    Sa pagkla alam ko, computer box or the ECU usually has to do with running the engine not in starting. trabaho iyan ng starter. so, the probable cause were those mentioned above and not the ECU. Kung ECU ang damaged o ignition coil, the engine will crank but it will not run .
    Hope this helps.
    Ride ko is corolla gli 93 and na-experience ko na wala crank pag on ko ng ignition due to flat battery.
    Kung manual iyang sasakyan mo, pasubok mo tulak start
    subukan mong i-push start. kung mag-start ay malamang baterya yan. kailangan nang palitan. pa-check mo sa dealer.
    Sep 2009
    Check mo muna battery terminals baka my lumuwag lang..
    Natural lang iyong ilaw sa dashbord mo pag naka on ang key. Possibleng dahilan loose connection sa battery, discharge or dead battery , defective starter. Check mo muna ito.
    Dec 2009
    thanks this helps me a lot
corolla94 gli problem
