Results 1 to 4 of 4
    May 2012
    Good day mga Sir I'm so confused lang po with my Corolla GLI 1995 model. I diagnosed it twice (TE1-E1 wire jump) and it always shows 12 and 52 codes which is both corresponds to a knock sensor issue, but the problem is I really can't find the location of my knock sensor. Tapos nagtanong din po ako sa isang surplus auto shop ng knock sensor for my car sabi sa akin is wala daw pong knock sensor yung oto ko.
    Please help me for those who have the same car model that I have.
    Thanks in advance po mga Sir.
    Feb 2009
    Stay away from chasing a wild goose. If the KNK sensor is giving you a code, it means that the engine maybe experiencing a misfire or shock loading. An example is Chevy S10 truck that gives you the knock sensor code if you drive on rough roads.
    Nakiki wi-fi lang
    Walang ngang knock sensor ang AE101 na PHDM. Hindi ba napalitan ng ECU yan? Gagana kasi for example yung 5AFE ECU na surplus kaso umiilaw ang check engine at ang ng error code ay sa knock sensor. Resulta ay nasa failsafe mode ang ECU at hindi sya efficient/optimized ang takbo.
    In comparison Yung AE111 na same 4AFE engine may knock sensor. Location nya ay sa likod ng engine block center position facing the firewall.
    Posted via Tsikot Mobile App
    sir paano po gumawa ng thread? gusto ko lg po malaman kung ano kalakas kumain ng gas ang 1994 corolla gli.... im about to buy ksi... sorry for wrong post.. di ko alam pano gumawa ng thread. thanks
Corolla GLI 1995 knock sensor
