Results 1 to 8 of 8
- May 2009
- 7
January 15th, 2011 05:51 AM #1Question lang po...pano po regular na maintenance nyo for your car and niccheck nyo from time to time sa car nyo?.....i have a corolla GLI big body....newbie lang po ako when it comes to cars....bumigay yung clutch master ko kagabi.....kakadala.....just wanted to learn from the gurus...thanks po in advance...
- Jan 2011
- 26
January 15th, 2011 10:17 AM #2pre gli din ako sana may magreply sa post mo para mapulot din ako ng mga tips sa car natin...
- Dec 2006
- 273
January 16th, 2011 11:11 AM #3Ang regular maintenance sa mga gasoline powered vehicles ay:
1. ENGINE OIL - color and texture nito. Tingnan mo rin from time to time ang level nito by using the dipstick. The level should be 3/4 not FULL..in order not to damage the oil seal especially when you're driving at high speeds.
2. SPARK PLUGS - Pag medyo masipag ka, try to clean the tips by using steel brush and kerosene, just to remove the carbon and soot. Kelangan din nasa tamang air gap ang plugs ninyo.
3. AIR FILTER - From time to time, pa bugahan mo ng compressed air ang air filter para di makabara sa paghigop ng hangin.
4. WATER level in RADIATOR - Always check the level kung nagbabawas ba or hindi. REMINDER: DON'T REMOVE RADIATOR CAP WHILE IT'S HOT! You can do this check before you leave the house.
5. CONDITION OF FAN BELTS - If they are glossy or parang plastic na matigas at madulas na, try to replace then of the same size and with adequate tension.
6. BRAKE and CLUTCH FLUID LEVEL - They should always be in FULL level. Kung nagbabawas, try to look for leaks. ALSO, try to check the condition of your brake shoes and pads, judge if they need to be replaced or not.
7. TIRE PRESSURE - Always check for the correct tire pressure. You can see the exact pressure if they are cold..meaning you haven't drove your vehicle less than 500 meters.
I hope these tips could help. There are still lots of gurus here where they can also share regarding this article.
- Jan 2011
- 26
- May 2009
- 7
January 20th, 2011 10:17 PM #5salamat sa mga tips bossing....laking tulong nito in taking car of my car....drive safe....
- Oct 2013
- 5
October 19th, 2013 02:31 PM #6Ano po ba pwede dahilan kapag naingay gulong kapag na apply ako break, especialy kapag maulan.. Thanks
October 22nd, 2013 04:41 PM #8
Does The Link branch require to take the exam onsite or do they accept printed results? Sa Paseo...
