Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Sep 2008
    Please help me..pangalawa ko ng beses ngayon dito sa tsikot forum..
    Ano po problem ng car namin kasi ayaw humatak ng maayos pag paitaas.Napakabagal niya umangat kahit nakatapak na ng todo sa gas.Dati hindi siya ganito.Please po intayin ko agad sagot nyo...
    Apr 2008
    matic ba auto niyo sir? pag manual pwedeng sa carb yan nangyari sakin ganto 2nd gear nakadiin ka 20kph hanngang dun lang parang sakal
    It might help to post the COMPLETE details about your car when you ask for help. We are not mind readers so having your car's details posted will be helpful... include any recent repairs and servicing done like tune-ups, etc.
    Sep 2008
    Thanks sa mabilis na reply..
    Kay Sir Kevin3000 oo ganyan nga nasa 20kph lang ayaw na kahit nakatapak ng madiin sa pedal..Manual ang car namin.Ano gawin sa carb kung sakali?Kagabi paguwi namin Laguna ay hirap na humatak kaya pansin namin na ang lakas namin sa gas di naman ganun dati-at kaya ang bagal din namin nakauwi.
    Kay Sir Ghosthunter.ang car namin ay corolla 99 xl.(manual).Kakatune up lang last January first week at napalitan naman din air filter,etc..,naiayos ang tappets.Yung clutch repair kit ay napalitan din last December..
    Sep 2004
    Usually, pag mahina ang hatak, one of the main causes ay worn-out clutch disk/pressure plate. Baka palpak ang pag-ayos ng clutch plate last December, since repair kit lang naman ang ginamit?
    Happened before to my 1980 Galant Sigma. Nung pinalitan, ok na uli ang hatak.
    Quote Originally Posted by Janhil View Post
    When you step on the gas pedal, does the engine rev up but the car doesn't accelerate? If yes, the other guys has found your problem for you. Your clutch is in need of replacement or at least adjustment if it is not yet fully worn out. If it just needs adjustment, its best NOT to drive it much without having it adjusted because it will burn the clutch disk.
    Clutch repair kit?? Did you already have your clutch disc replaced or something else was fixed? Leaking fluids (oil or hydraulic fluids) that contaminated the clutch disc can also have the same effect (sliding clutch).
    Sep 2008
    Salamat talaga sa reply mga Sirs kasi di namin magamit ang car ngayon.TAnong muna kami dito sa forum bago namin dalahin sa shops para mas may idea kami ano ang tamang ipagawa.Mas mararami matitino magpayo dito kesa punta agad sa shop.
    Sir Galactus ibig mo sabihin baka nga worn out na yung clutch so yung buong clutch parts na ang papalitan namin?Magkano kaya ang ihahanda na gastos sa ganun na repair?KAya napalitan yung clutch repair kit,one time nasa biyahe kami naubos o na drain yung clutch oil kaya nagtulak kami buti na lang nasa gate na kami ng subdivison namin..Pero nung i check nung mekaniko ay repair kit lang pinalitan
    Sep 2004
    Yup, mukhang may tama na ang clutch. Don't know much about Toyota parts, kasi never pa ako nagkaroon ng Toyota, pero mura lang ang pressure plate/clutch disk (basta hindi brand new at original).
    Had the exact same symptoms. Kahit todo-apak sa silinyador, mga 15-20 kmh lang yung takbo, until one time, while we were curising, may nangamoy sunog sa engine bay tapos ayaw ng umandar ng kotse. Yun lang ang pinalitan, tapos ok na ulit.
    Apr 2008
    pwedeng sa carb siya palinis mo, try mo din sa fuel pump try mo ipalinis..
    sa clutch kasi mararamdaman mo sa 1st gear palang pagarangkada hirap na ung engine pero still mabagal pa din.. pero pagrectahan na back to normal na un dapat
    Dec 2007
    Sa paakyat lang yata lumilitaw ang problemang ito. Ang tanong ko: may buwelo ka ba? Nasa anong gear ka pag hirap siya? Did you try downshifting to first gear?
    Apr 2013
    hello mga sir, skin din pg paakyat e hirap na sia lalo na pg my kht 2 akong sakay d n nia kaya..tska un hatak ng 1st gear ko mahina compared sa isang corolla 1.3 na gamit nmn d2 sa offic ok nmn kht puno malaks parn hatak..help nmn po
    Quote Originally Posted by Yorak AutoFold View Post
    sir reminder lang po BAWAL ang text style typing.
    Feb 2013
    chances are fuel filter yan.
    May 2012
    same problem here parang hirap makabwelo.and parang nasinok din ung sakin
    querry lang din sir about sa clutch..pagpasok ng 1st gear and rease parang garlgal na bakal ung tunog nya tapos nid mo pa tapakan ulit ung clutch hanggang matimpla at mawala ung ingay and minsan pag mainit na or matagal na gamit parang hirap na sa arangkada.kahit nakatapak na sa gas parang ang tagal ng response ng engine.ano kaya possible problem and estimate ng damage..toyota xl 96 model po ung car
    Oct 2011
    pa tune up niyo muna sir. change lahat ng filter and subukan niyo high octane or cetane na gasolina.
    Sep 2008
    Thank you talaga sa mga ngre-reply sa akin.Salamat sa oras ninyo.Till now ay di pa namin nailalabas ulit yung car.Tommorow ay Saturday sana nga ay madala na sa shop..
    Sir Woohoo,yes kapag paakyat madalas ganun..naka second gear na hirap pa rin grabe bagal umakyat,kakatakot baka bigla umatras pababa e.dalas pa naman kami daan ng Nagtahan bridge pag umuuwi at bumabalik mula Laguna.
    Sir Ghosthunter,yes nag rev up naman ang engine at nag accelarate naman pero super bagal sa umpisa tapos maya naman ay arangkada na rin.Halos parang di makaya humatak sa umpisa.Hindi pa napapalitan yung clutch disc.Yung lalagyan ng clutch fluids kasi one time ay bigla natuyo habang tumatakbo kami,then nung gawin nung mekaniko ay yung repair kit lang daw ang palitan.tapos naman nun ay umandar naman ng matino.
    Pero same effect din pala yun?,Bukas Saturday ay dalhin namin sa shop kaya lang may pasok ako half day,kaya sana nga patulong ako sa inyo mga Sirs para pagpunta ko sa shop alam ko na agad sabihin ko ng di nangangapa.Konti oras ko kasi sarado na agad mga shop.
    Sir Kevin,palinis ko din yung carb at yung fuel pump.
    Thanks ulit mga Sirs,pag umokey na paalam ko agad sa inyo laki ng tulong nitong forum na ito sana tumagal pa ito.
    Apr 2009
    paps baka sliding na clutch mo.. kung manaul ka, testing mong ibirit ung oto kapag naka aircon, kapag parang matic ung arangkada nya, sliding na nga clutch mo, kylangan ng palitan..
    try mo muna pa compression test, baka mahina na ung engine mo!
    Mar 2007
    sir normal ba ang pag "roar" ng engine mo pag naka idle ka?,
    if normal naman wala siguro problem sa carb.
    ipacheck mo nalang ulit clutch assembly mo, at compression test...
    goodluck amigo! keep us posted...
    Jun 2008
    ilang taon na car mo? kung last 9yrs pataas palitin na ang cluch lining p_plate L-bearing mo tapos patune up mo na din
mahina hatak??
