Results 1 to 5 of 5
    Apr 2011
    recently i noticed that my speedometer dial (needle) has wiggly movement. is there a problem with my car?
    three possibilities:
    1. improperly inserted at transmission housing.
    2. improperly inserted to speedometer housing.
    3. the cable is about to break. prepare to buy a replacement cable.
    Jan 2009
    Probably the cable is binding with the protective sheathing. The lubrication tends to dry up as the cable ages. Try pouring gear oil into the speedo cable from the meter side.
    Apr 2011
    thanks....
    Feb 2011
    speedometer cable po lang yan :-)
speedometer's dial
