Results 1 to 14 of 14
    Jan 2009
    Bumigay na yung Auxillary Fan motor ng Vios (2009G) ko.
    Ang First symptom parang humina at nagloloko yung aircon ko.
    Akala ko aircon talaga may sira kasi due na niya talaga for Major Cleaning.
    Ang kasunod nag-overheat na ko. Buti na lang malapit na ko samin.
    Nakita ng mekaniko ko from toyota casa, motor ng aux fan ang culprit.
    Nagtanong ako sa Denso 8K plus ang bagong motor pa lang (housing and blade not included).
    May napgtanungan ako replacement NASA 2.5K lang brandnew from Taiwan daw.
    Ask ko lang sana kung may nakasubok na kaya ng replacement motor na ito from Taiwan???
    Tatagal kaya?
    Pls Guys..kailangan ko ng suggestions at tulong ninyo..
    KAILANGAN KO NG BUMILI AGAD PARA MAGAMIT KO NA AUTO KO...
    TIA
    IMO okay na siguro sir yung Taiwan at least bnew. Although hanap pa kayo baka may mas mura pa.
    Tanong ko lang sir. Paanong "nagloloko" yung aircon nyo? Samin kasi after ipalinis aircon (linis lang walang palit ng aircon parts) napansin ko bihira na lang lumakas yung setting ng aux fan, yung rinig yung tunog talaga na malakas yung fan setting nya bale. Vios 2008 po unit namin.
    nung pinalitan ko ang aux fan ng sentra ko a few years back. less than 1.5K ang siningil sakin, including labor. ewan ko kung japan o taiwan talaga, but it's still functioning.. actually, mas tumagal pa nga yung nakuha ko sa rotonda kaysa yung casa-sourced na napakamahal..
    at hindi nga kasama ang housing and fan blade..
    What's the mileage of your Vios? Pretty early for the aux fan to give in IMO. Taiwan replacement should be fine; you can also check with your suking electrical shops and the Banawe shops so you have a better idea on the going prices and choices.
    Sep 2006
    Taiwan auxillary fan P1350 (circuit brand)
    Kung kailangan mo ng blade P300
    May 2004
    Pareho tayo TS... ganoon din na experience ko.. I opted for original kasi may nag sabi na ang taiwan brand eh hindi tumatagal... mine is about 30t km nung nasira... Denso ko na binili.. try mo sa toyocars or toyorama kung meron sila baka mas mura... Ako nagulat din ako sa price yung luma kong kotse mura lang ng AUX fan Motor eh...
    Tumawag na ko sa Toyorama. Langya P7600 motor pa lang. Toyota daw. Pag blade replacement lang, P450.
    Sure bang may sira na motor pag sobrang bihira na lang sya bumuga ng malakas? Minsan pagpark ko sa garahe namin tsaka lang sya bumubuga ng malakas pero saglit lang. Pag nilakasan ko aircon thermostat tahimik lang buga nya, mahina.
    Sep 2006
    Bro bkit kailangan mo magpalit ng blade umaalog na ba?
    Jan 2009
    Guys salamat ng marami sa inputs ninyo..
    Bumili na lang ako ng original denso. Nakuha ko ng 2850! Nabili ko sa Authorize denso shop sa tapat ng Mitsubishi Cars along EDSA (southbound) sa may Balintawak.May signage na DENSO.
    Highly recommended itong shop na to, kasi among the denso authorize shops in Metro manila, proven na isa ito sa may pinakamurang mga parts like drier, expansion valve, compressors, etc. Medyo familiar din kasi ako sa mga price ng aircon parts dahil kakatapos ko lang bumili ng Original denso expansion valve at drier for a major aircon cleaning ng vios ko.
    Buti na lang di ako kumagat dun sa isang Denso Authorize service center sa loob ng Auto House sa Pasig. Imagine prinesyohan ako ng 8500 dun! Last price daw ay 8200. Klaro yung usapan namin na price yun ng Fan Motor lang, meaning aware siya na di kasama housing and Blade..
    Be careful guys sa pagbili natin ng piyesa. Mas maganda mag-canvas muna tayo maiigi.
    About dun sa fan motor na pinalitan, talagang palitin na din. Wasted na yung armature at carbon brush. Hindi pala sealed ang motor dahil binuksan (easily) ng mekaniko.Talagang napaka dumi, sabi nga ng mekaniko dapat yearly nililinis din yung loob ng motor para mas tumatagal ang fan motor..
    Ayos na uli si Vios ko. Wala ng Overheat. Lamig na din AIRCON..
    Quote Originally Posted by ortawuk View Post
    Nice. Ok na yang P2850 for a brand new motor.
    Tsaka magkano rin po parts ng aircon? Expansion valve, drier? Thanks sir.
    Jan 2009
    For vios:
    Expansion Valve - 1350 other authorize denso dealer - 1500 up
    Drier (without filter kit) - 900 other denso dealer - 1100 up
    filter - 700 (di ko alam kung magkano sa ibang denso shops)
    Usually pwede pa naman gamitin yung lumang filter kit(im not sure kung tama yung term) kasi mukhang matibay yung built, parang washable siya, pero pabugahan na lang ng high air pressure para mas safe, kasi sabi ng technician sensitive sa tubig ang system. Dapat wag mapasukan ng tubig.
    Compressor - 16500 kasama na magnetic clutch
    Ang pinaka ok sa lahat, pag dito ka bumili, authorize denso dealer shop to. Sure na di replacement ang item.
    Look for Mam Flor. Pwede pa yata magbigay ng 5% discount..
    P.S Sorry Moderator mali pagkaka spell ko ng Auxiliary Fan. Auxillary nailagay ko. Mahina talaga ko sa math.. Paki edit na lang po kung pwede pa..
    Hi Sir,
    my Avanza at 98000 km --- Aux fan ---go for the original. dito sa Celica (Where TQA and toyota commonwealth parts supplier) 5t plus lang ang motor. no need to change housing and blade. works fine now.
    For vios:
    Salamat sir.
Auxillary Fan Motor
