Results 11 to 19 of 19
- Jul 2009
- 3,604
August 20th, 2012 01:50 PM #11The Kumho Ecsta are good tires.
The Kumho Solus, not so much.
The Hankooks overall are good, but I have no feedback with regards to each specific tire model (as with all manufacturers, some models are better/worse than others).
I'd stay away from the Sonars or Runways unless you're really on a tight budget. I don't have much info on those either.
The A Drive should be a little more upscale than the ASPEC. Newer tire design.
No ASPEC ones? Those should be cheaper than the A Drives and drive pretty well. These tires are stock on some of the Camry models.
Btw, for safety concerns, the 2 new tires should be at the back rather than the front.
- 54,260
August 20th, 2012 02:00 PM #12i believe the two new tires should be in front:
1. they support the heavier part of the car;
2. that's the end that gives you directional control;
3. that's the end with the stronger brakes;
4. that's the end that gives you power.
when your rear tires fail or slip, you can still get control of the car with your manipulation of your front wheels.
when your front tires fail, all you can do is pray.
some authors believe shifting from rear wheel drive to front wheel drive, is a good commercial decision (costs!) but a bad engineering decision.. putting your poorer tires up front compounds the problem and increases the risks..Last edited by dr. d; August 20th, 2012 at 02:08 PM.
- Jul 2009
- 3,604
August 20th, 2012 02:14 PM #13Nope.
New tires in front, worn at the back = oversteer.
New tires at the back, worn in front = understeer.
In any case, it is easier to control understeer as opposed to oversteer.
If it's the latter, you won't even have the chance to pray when you've spun out already.
If you must replace tires two at a time, NEW TIRES AT THE BACK.
This explains itLast edited by mda; August 20th, 2012 at 02:18 PM.
- Aug 2012
- 35
August 20th, 2012 02:36 PM #14you know what, you guys are killing me. hahaha.
ano ba talaga mga kuya? katakot naman. buhay ko to ah. haha. front or back? :P
- Jul 2009
- 3,604
August 20th, 2012 02:49 PM #16
- 54,260
- Jul 2009
- 3,604
August 20th, 2012 03:18 PM #19
i confess, my seagull review is from internet literature. that so-called aircon issue is a...
BYD Seagull
