Results 1 to 4 of 4
February 4th, 2012 01:02 PM #1
Things that I need to fix with my beloved Corolla 95mdl SE Limited:
Are this a common problem?
1. Radiator - the water/coolant looks like chocolate (hehe)
2. Timing Belt - i don't know when it was replace
3. Cylinder Head - sounds like it has a typewriter inside the engine
4. Power Steering - lot of oil leaks and hoses are too expensive to replace anew
5. Engine Oil Leaks - Oil seals and oil pan
6. Shocks - needs OEM replacement
7. Power Windows - too expensive to repair
February 4th, 2012 04:34 PM #2
95mdl GLi owner din car ko.
1. Flush mo muna sir radiator mo sir, palitan mo distilled water, then observe, bAka accumulated rust lang yan. Sakin malinaw tubig.
2. Palitan mo nalang din kung hindi mo alam kung kelan pa last pinalitan, mas gagastos and lalong hassle pa yan pag nalagot yan ng bumabyahe ka.
3. Yung typewriter sound na yan sir sa GLi, parang sakin, pag cold start, rinig mo, pag tumakbo na and mainit na makina, wala na halos, onting onti nalang. Ganyan na ata talaga tunog nun, wag lang ung sobrang lakas.
4. I changed mine with a surplus unit, yung last owner kasi taiwan rack and pinion lang nilagay and nung nagleak, wala ako makitaan ng repair kit, so no choice, surplus nalang. Sakit na toh ng corolla sir, power steering.
5. Sa oil pan wala ako problema, sinabay ko na toh sa pag change ng timing belt, top overhaul, lahat ng oilseals palit, wala ng tagas, lakas pa makina.
6. Hindi ko pa sir napapalitan yung shocks, by this year siguro
7. Driver side backseat, not functioning sakin, pag may time, pagawa.
Enjoy the car sir.
- Mar 2004
- 652
February 4th, 2012 09:37 PM #31. kung meron ka konting kakayahanan mag butingting, here's what you should do. a. remove top radiator hose from rediator, put plastic cover on the opening of the radiator. Connect a pvc tube or anything to extend it beyond the bumper. now, insert a hose on the opening of the radiator (remove radiator cap). start the engine, and ope the water tap just enough to replenish the water in teh radiator. Stop when water coming out from the engine becomes clear.
2. Better to replace sooner than sorry later
3. Have a good mechanic check your valve tappet clearance. Pag ang tunog parang nagmamakinilya, malayo ang agwat ng rocker arm sa valve tappet.
4. Power steering is never a strong point of toyota. But better to have it repaired as later, it will damage your pump (just like what happened to me)
5. No experience on this yet.
6. due for replacement na rin ang front shocks ko
7. Kung mekanismo lang, dami surplus dyan sa evangelista. dyan ako naka kuha, harap at likod pa. Malamang stuck lang ang gears nyan. sabihin mo lang kung kaliwa o kanan
Hope this helps.
- Mar 2011
- 42
February 5th, 2012 09:35 PM #4Bro,
Sa akin Big Body din halos parehas tayo ang status
1. Radiator - I agree po kay Sir burjegol ganyan din ginagawa ko. For sure top water lang yung linalagay mo dapat po distilled water ako po absolute water hehehe
2. Timing Belt - papalitan ko na din to kapag may chance na kailangan buksan ung engine kaso sa ngayon wala pa
3. Cylinder Head - ganito din sa akin ang ibig mong bang sabihin kapag umaandar ka na tapos bigla mong maririnig na garalagal ung tunog di ko pa nga pinapacheck ung sa akin maybe we can help on each other dito
4. Power Steering - ang mahal sir ung pumpkit pero kung makakahanap ka nang replacement okay naman ganito din sa akin
5. Engine Oil Leaks - Done with this pagawa mo na din ung mga ibang leaks
6. Shocks - KYB? ba sir
7. Power Windows - sa banawe, evangelista marami niyan sir
