Results 1 to 11 of 11
    Nov 2007
    hello mga bro, kindly help naman sa 2c turbo (japan) ko 2x na dukot still kumakain pa rin ng langis ayaw ko na sana ibenta kc mlaki na gastos ko,can u give advise me or mgandang suggestion. your help is highly apprecuiated.tnx.
    Have a compression test done first (wet and dry) so that you can determine what exactly is the cause of the loose compression. Also, "dukot" isnt really an adviseable way of properly overhauling an engine. On our 1300 Corolla before, i changed all the gaskets and piston rings using original parts and it didnt cost more than 15K (just shop around for the parts yourself).
    Quote Originally Posted by Janjas View Post
    iwasan po natin text speak.. 0
    compression test nga:
    here's a data of 2c-t's
    http://tsikot.yehey.com/forums/showthread.php?t=40308
    might be good to let us know any other things you noticed ex. like hard start, white smoke idle, etc...
    Nov 2007
    not really a hard starter but emits white smoke, ang idle not really good very shaky specially when it is cold, and there a smoke coming out on my dips stick. some of friends told me that the turbo may be damage also pero mlkas pa rin ito humatak, should i replace my engine?or can be repaired? how much will it cost me?thanks.
    if smoke coming out on dipstick, have a compression test...
    use the data.
    if only the white smoke emits on idle after pushing hard the engine. example: after a stop on traffic lights, the smoke appears.... then it's likely the turbo.
    a 2c-t surplus costs 18k-up.
    Bakit 2 beses ka nagpadukot?
    How is your liner/sleeve? Honing? Oversizing of rings? Piston grooves?
    Turbo noise (sayad/m.m. contact)? Oil soaked intercooler(if any)?
    There are 4 possible outlets of oil that should be maintained at a minimum or zero
    1. Oil seal of turbo
    2. Oil seal of valves
    3. Oil ring of piston
    4. Oil seal front and main(0)
Help need on my FX 2c turbo
