Results 1 to 4 of 4
- Mar 2011
- 42
January 16th, 2012 10:13 PM #1Hi Sirs,
may katanungan lang po ako tungkol sa brake and clutch fluid bakit kaya ganon nung tiningnan ko ung color nang fluid kulay brown siya ano kaya ibig sabihin nun diba dapat kulay puti un
any suggestion lang po
regards;
Roland
January 17th, 2012 06:15 AM #2
Sa brake master naman pwedeng nangaling sa brake piston ng break drum dahil sa rust, maganda pa overhaul mo yung break drums palit ka rubber cap and then ibleed, sa clutch master try mo lang ibleed din sir para malinis, posible din mix brand din brake fluid kaya ganun
BANNED BANNED BANNED
- Jun 2011
- 125
January 21st, 2012 07:13 PM #3the dot 3 and dot 4 brake fluid are hygroscopic or has a tendency to absorb moisture from the air. it has to be replaced every two years. failure to do so makes the brake fluid contaminated by moisture the brake components get corroded, as a result, the brake fluid changes in color from amber (pilsen beer color) to light or dark brown.
January 21st, 2012 08:04 PM #4
sa rubber ng mga clutch master cylinders mo yan.sa primary o sa slave. either sa dalawa.
