Results 1 to 13 of 13
    Mar 2011
    Mga Sirs,
    may question ako about sa AE101 nagdridrive ako kanina tanghaling tapat tirik ang araw naka aircon syempre then napansin ko na humihina ang aircon hanggang sa nawala ang lamig ang ginawa pinatay ko muna ung aircon nag drive nang 2kms then binuksan ko ulit ung aircon ayun bumalik ung lamig ano kaya possible problem nun di naman nag high ung temperature ko any advise
    thanks
    i would check:
    1. my auxiliary fans. maybe one or both of them is/are intermittent, or slow down when hot (think: bearings/bushings; repair or replace).
    2. my radiator water level.
    3. my freon level.
    Mar 2004
    this had been the problem of my gli before. bigla lang mawawala ang lamig ng a.c after running say 30 min. then pag pinatay mo and start again say after 5 minutes, gagana na naman ulit.
    this problem was corrected when napatama na ang karga ng refrigerant sa system. I think and climate controller niyan ang nag-stop ng compressor for operating.
    try mo ito (if you have a little tinkering capabilities).
    next time na bigla lang huminto ulit ang pag lamig ng a/c, first check the rpm of engine. then try mo bunutin ang connection sa high pressure switch. observe if there is a change in the rpm of the vehicle. pag mata-as pa rin, that means ang climate controller mo ang nag activate to stop the compressor. try mo pa dagdagan ang karga ng refrigerant.
    and don't listen to those a/c technician who will try to BS you by saying sira ang compressor mo
    May 2010
    Ganyan din akin 95 XE, ginawa ko nagpalit ako compressor at pina manual ko na yung aircon ko mas malamig. Yung temp controller pinalagay ko sa labas kasi yung iba nakatago mahirap ma adjust kung malamig o mainit pag nakatago, pinalagay ko ko sa ibaba portion ng radio.
    Aug 2010
    i would check:
    3. my freon level.
    check/replace the automatic thermostat switch, may be it is failing and out of it's operation sequence. mapapansin mo it ticks off then matagal bago mabuhay ulit than an usual or in some case hindi na nagsswitch "ON" so hindi na talaga lalamig.
    Aug 2010
    i would check:
    3. my freon level.
    Jan 2012
    ngha-high pressure po yan, mapansin ngyeyelo un tube nyan kya after mo i-off un a/c switch eh nbalik ulit un lamig. hindi ngo-automatic un compressor u. make it check sa a/c specialist n kilala u pra hindi masyado mahal singil or libre pa.
    Mar 2011
    Mar Sir,
    okay naman ung aux fan, kaka recharge lang nang freon tapos normal ung water level ko
    sorry po newbie lang ano ung climate controller? saka saan po yung pressure switch?
    tapos naka manual lang yung thermostat switch ko
    Feb 2003
    Compressor Coil sira ng car mo 99% sure
    Mar 2011
    Sir,
    Compressor coil oil. magkano kaya aabutin nun? saka kailangan ko po bang i discharge pa ung freon
    Feb 2003
    Isang compressor coil nasa 8 thou php po. Hugis bilog ito na nakadikit sa compressor mo... Pag nainitan ito ng matagal nagloloko na ito and yung aircon mo hangin na lang ang buga.... Yung freon sa alam ko kailangan din dagdagan after palitan ng compressor coil
    Just to remind you na iba ang compressor coil sa magnetic clutch ahh. Yung magnetic clutch ang nagpapa "tik" or automatic sa pag idle pag inopen mo aircon mo
    So if the compressor coil is not functioning well, ndi na din gagana yung magnetic clutch.. Pero sa tigin ko naman compressor coil lang talaga sira ng auto nyo
    Mar 2011
    hello,
    thank you sir as pag advise un nga kapag wala na ung lamig nawawala na din ung "TIK"
    replacement na po ba ung ganong price na 8k
    Regards;
    Roland
    Feb 2003
    Sir yung 8000 php orig parts na yun. Sa honda cars manila ako nagpareplace. Nagkaganyan yung honda city ko ehh. Yung una nga akala ko baka may dumi lang na bumara so pina cleaning ko.. Yung pala may sira yung compressir coil. Buti na lang na detect haha
AE101 - Aircon problems
