[SIZE=2]Gud day Guru's!Just want to share my experience and ask advice na din sa inyo.I had an overhaul lately of a 2e corolla 91 engine.Plan was to make a Top overhaul lang kasi busted na ang HG.I was running out of coolant, tumataas ang temp ng 3/4,and white smoke coming out of the tailpipe.When engine was dissassembled,discovered may alog na mga pistons.It was already oversized at .75mm kaya pati mga piston rings sinama na sa overhaul.thus the reason kung bakit napunta na sa general overhaul.I asked my mech.kung pwede pa yung cylinder head,told me kaya pa tumagal,though sa pag examine ko kinakain na ng minerals yun aluminum.mekanik told me ok pa raw yun block,sa tingin ko mukha okei pa no cracks sa walls on the block etc.but he never recommended any machine shop,maybe because manipis na yun Head,everything was put back,break in at idle ok,went on a drive ok,pero didnt last long because pumalya ang mga sparkplugs.checked it up again at basa sila ng oil.mekanik changed the plugs from stock to platinum and drove it,checked again voila...tuyo, normal ang burn.he told me na mahina mga plugs ko.unfortunately,may blow-by pa din kahit before the overhaul meron sya.ang natanggal lang after the overhaul is the 3/4 high temp. and the loosing ng coolant.I checked the dipstick and it was spewing smoke.I'm at loss already,just spent a considerable amount para lang mapatakbo ng maayos pero eto na naman."mawawala,bumabalik mga problema".Will I opt for a new engine na or kaya pang ma-save yun stock na engine ko?any advise?I doubt my mekanik na kahit matagal na namin kilala sya.Pasensya na sa nobela mga kaibigan at more power to our forum!
[/SIZE]
Driven To Thrill!
