Results 1 to 7 of 7
    Dec 2012
    Fellow tsikot members,
    Need your advice with regards to my Toyota Vios 1.5G 2004 model. It takes me three times to start the engine. I have noticed the engine was too noisy whenever I turned on the AC. The oil was replaced together with the new spark plugs two weeks ago. I even brought it to a well known car care services and they clean the so-called "servo", but unfortunately, did not solve the problem.
    Regards,
    Ronald
    Jul 2011
    Sir pa check mo po ung battery, baka malapit ng mag end of life ang battery mo.
    Quote Originally Posted by rpstaana View Post
    Regards,
    Ronald
    if its too noisy when you turn on the aircon, nasa compressor pulley ang problem nyan.
    yung hard starting, its the battery.
    Oct 2011
    yes, malamang pulley yan. kakapalit ko lang ng pulley pero sa alternator. same type of noise.
    Dec 2012
    Sir - Thanks for the advice. The battery was replaced last August 2012. Malakas pa po yung redondo.
    Dec 2012
    ok pa-check ko po yung pulley sa compressor...thanks..
    Regards,
    Ronald
    i think compressor bearing ang problema. Baka nabasa ang compressor mo sa baha.
Hard starting/Engine noise
