Quote Originally Posted by therp2paz View Post
ng search po ako at nalaman ko na un nga ung tawag dun ! choke breaker diagpragm nga po, ang problema nga po ay ung maiksing hose na nakasalpak duon ay hindi na humihigop, db yun ung hihigop upang unti unting mag open ung choke during a cold start, ang problema po ay hindi na humihigop yung hose
check your thermostatic switching vacuum valve (TVSV) and the hose connections. this tvsv is installed on the intake manifold where coolant passes. there should be two hoses: one, from the intake side of the manifold, the second port/hose goes to the choke breaker.
