Page 1 of 2 12 LastLast
Results 1 to 20 of 92
    Jul 2013
    Starting a new thread for the Yaris Cross as the older thread was for the XP210 - Japanese, European and Australian markets
    AC200
    Jul 2013
    Philippine Specs Of First-Ever Toyota Yaris Cross Revealed In Government Paperwork | CarGuide
    Filed just last July 14, the first-ever Yaris Cross is confirmed to be packing a 1.5-liter 4-cylinder engine. Since there’s no mention of “hybrid” in the paperwork, we can assume this could mean the 2NR-VE engine found in Yaris Cross models launched throughout the ASEAN region.
    Aside from the engine, the LTO documentation reveals the Yaris Cross’ wheel and tire size for the Philippine market; and they’re beefy at 215/55R18 for both the front and rear ends. In addition, the paperwork reveals the general dimensions:
    Overall Length: 431 cm (4,310 mm)
    Overall Width: 177 cm (1,770 mm)
    Overall Height: 161.5 cm (1,615 mm)
    Wheelbase: 262 cm (2,620 mm)
    Ground Clearance: 26 cm (260 mm)
    Curb Weight: 1,250 kg
    Net Capacity: 350 kg
    Gross Vehicle Weight: 1,600 kg
    Dec 2019
    ice15 why 2023? its proposed as 2024 model year vehicle in PH.
    Spied: PH-spec 2024 Toyota Yaris Cross has arrived
    Jul 2013
    para madali since the AC200 is presently available na sa Indonesia and Cambodia...
    and, if Toyota PH releases it this year. 2023 yung nasa OR/CR nya
    Jul 2013
    Jul 2013
    2024 Toyota Yaris Cross starts at PHP 1.2M; Hybrid available | Autoindustriya
    here are the approximate (but almost exact) prices:
    2024 Toyota Yaris Cross HEV – PHP 1.6 million
    2024 Toyota Yaris CrossV 1.5 CVT 2-Tone – PHP 1.3 million
    2024 Toyota Yaris Cross 1.5V CVT – PHP 1.3 million
    2024 Toyota Yaris Cross 1.5G CVT – PHP 1.2 million
    at 1.2 to 1.3 mil, this will go against the BRV v or vx.
    The Corolla Cross non Hybrid is a "G" trim and starts at around 1.3m php already.
    I am a bit confused why the Yaris Cross would enter the market at 1.2m ~ 1.3m php price range for a non Hybrid "G" trim. Should it start around 1m to 1.1m php instead where the Raize's price peaked and to give a price disparity between the Yaris Cross and the Corolla Cross which is a size larger?
    If you look at sedan pricing from Wigo to Vios to Corolla the same has applied in how they are priced, so I am wondering why the Yaris Cross did not follow the same pricing structure/positioning? Because they "can"?
    Just a thought I had. I was hoping the smaller Yaris Cross would allow for the HEV model to be priced closer to 1.5m range as the Corolla Cross HEV is around 1.68m php. As it stands, TMPH priced the Yaris Cross Hybrid 80k php "cheaper". Might as well go with the Corolla Cross from a size perspective then with the minimal price difference as you get a more "spacious" vehicle for the money with the same Toyota Badge right? (although the Corolla Cross is already old compared to the Yaris Cross, but for discussion I'm taking that out of consideration and just comparing price wise based on the article)
    On another note, I was wondering why I was "clicking" and ad keeps showing instead of the reply page, and it appears the website is showing png ads now where the background is transparent and you can see the button behind but if you click, the ad is overlayed on top of the website. Frustrating especially since I've uninstalled ad block and now this is what it is being done to get "clicks" on the ads on here.
    i think pricing is a bit different, if the car comes from japan.
    taxes, for one.
    Nov 2019
    Based on TNGA platform na ba to?
    That's why I only open tsikot when I am on laptop with Adbliocker installed.
    It is impossible for me to open tsikot in mobile browser dahil sa mga Ads.
    Jul 2013
    Quote Originally Posted by carxynogen View Post
    No. DNGA-B sya
    Jul 2013
    weeks old pricelist
    Jul 2013
    Prices, Specs Of First-Ever Toyota Yaris Cross For Philippines Revealed | CarGuide
    For the Philippine market, the Yaris Cross will be available in three variants at the following prices:
    1.5 G CVT – P 1,199,000
    1.5 V CVT – P 1,306,000
    1.5 S HEV CVT – P 1,598,000
    Dec 2019
    I've also wished that the new Yaris Cross will have 1.0 turbo found in Raize. It has the same engine with the Avanza/Veloz and Vios. With the entry level cross you can get a TOTL Raize 1.0 turbo and save almost 100+k.
    Totl Yaris Cross isn't in a good place either. Just 100k more will get you into the Corolla Cross HEV which has a better petrol engine, and something like 10x the hybrid capacity.
    Nov 2019
    Jampacked with features naman yung TOTL Yaris cross vs Corolla Cross HEV unless if you are only for the engine and TNGA platform. I doubt normal consumers can be swayed by that easily if feature wise na pag-usapan.
    Siguro if mataas pila sa unit na to, then probably sales person can convince buyers na mag Corolla Cross HEV nalang po kayo, mataas pa po pila Yaris Cross.
    Nov 2019
    Id go for 4 cyl than 3-cyl for this pricepoint.
    Also, confirmed na ba na DNGA-based to?
    Dec 2019
    DNGA based ang ASEAN Yaris Cross.
    TNGA sa JDM, USDM, Euro and Australian markets.
    Sent from my SM-S901E using Tsikot Forums mobile app
2023 Toyota Yaris Cross
