Results 1 to 20 of 140
    Jul 2013
    W100 - 3rd Gen
    Meet the all-new Toyota Avanza | TopGear PH
    Powering the third-gen MPV are two engine options: a 1.3-liter in-line-four with 97hp and 122Nm paired to a five-speed manual transmission on the E variant, and a 1.5-liter capable of 105hp and 137Nm mated to either a five-speed manual or a CVT for the G. For the first time in the model’s history, this version runs on a front-wheel-drive configuration.
    Jul 2013
    Jul 2013
    Nov 2019
    Parang naging Xpander tingnan sa side profile.
    Sep 2010
    Dec 2019
    engines are still carried over. 1.3L and 1.5L 1NR-VE & 2NR-VE
    Under the hood, the all-new Avanza is powered by either a 1.3-liter 1NR-VE or the 1.5-liter 2NR-VE four-cylinder Dual VVT-i engines. The former puts out 98 PS with 121 Nm of torque, while the latter generates 106 PS with 137 Nm of torque. With the new front-wheel-drive layout, the four-speed automatic has been replaced in favor of a new CVT with sequential shift. Meanwhile, the five-speed manual transmission has been carried over.
    Its a relatively new product. Toyota won't be caught jumping into this small turbo engine trend especially in a market where this Avanza is selling thousands.
    Jul 2013
    Jul 2013
    Wikipedia mentions that the new Avanza uses D-CVT
    I wonder if the "gear" is for the first gear, or the final gear
    Dec 2019
    also the upcoming hybrid powertrain. turbocharged versions might not come if favor of the hybrid powertrains..
    Dec 2019
    I saw the new avanza in flesh rolled here in dona soledad ave. better living.
    It was an avanza 1.3 e in dark green. Size is almost as close as the gen 1 innova.
    Sent from my SM-N970F using Tsikot Forums mobile app
    Jun 2005
    Yikes. Almost a gen1 innova with a pitiful 1.3 liter engine. Hirap na hirap siguro yan
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    Jul 2013
    Quote Originally Posted by sirkosero View Post
    the body is lighter, thanks to its new platform
    plus I'm sure Toyota tuned the engine and CVT to handle the load.
    comparing the new Avanza E vs the Rush on paper, the Avanza is only 4hp and 12Nm "weaker" than the Rush. Note that the heaviest Avanza is 60kg lighter than the lightest Rush
    ... baka latang darigold ang katawan, to save on weight...
    joke lang po.
    Dec 2019
    It might hirap when fully loaded. Much better get a manual version than a cvt.
    They should make the 1.5L as standard across the range. Like its competitors.
    The new Avanza is only slightly heavier than the Vios.
    Base 1.3J weighs 1090kg, top 1.5G CVT weighs 1140kg.
    The 1st gen Innova is about 160mm longer, 40mm wider, and about 55mm taller than the new Avanza. The Innova also uses a heavier body on frame construction, while the new Avanza uses a stretched version of the lightweight DNGA platform used by the Raize.
    *The gasoline 2.0 AT variant of the old Innova/Kijang is about 410kg (903.9 pounds) heavier than the Avanza 1.5G CVT.
2022 Toyota Avanza (3rd Gen)
