Page 26 of 54 FirstFirst ... 1622232425262728293036 ... LastLast
Results 501 to 520 of 1463
    Apr 2010
    Thanks dr. d for your opinion!
    Rode an Innova J Uber yesterday. Surprisingly it's really decent and far better inside compared to the Sportivo or Adventure. Exterior just needs alloy rims and fog lamps.
    Great choice if you can drive a manual.
    Agree. I understand it already has ABS and power amenities.
    Lexus 18s with beefy tires nalang kulang.
    Jul 2003
    ano po RPM ng 2.8G sa 100kph?
    thanks
    Dec 2007
    Quote Originally Posted by kurt View Post
    thanks
    Nasa 1700 rpm with the G A/T while running on the skyway having 2 adults on board.
    May 2009
    had experienced driving the new innova for a few km only.....eco mode....hambilis na nung eco mode. biruin mo 2nd gear pa lang e malapit na mag 60 kmh...panu na lang kung power mode.
    mejo pinerstaym din ako nung AC controls.
    napansin ko parang mas rough ang andar nung 2.8 gd kesa nung kd series. tapos ilayo mo konti tuhod mo sa kambyo bago mo paandarin kundi pilay ka.
    Dec 2015
    Test drove one during the weekend. Smooth ride comparable to a sedan, steering is on the heavy side but it doesn't feel like it despite the size.interior feels classy. Coñio na talaga ang Innova.
    Sep 2004
    anyone who has the v variant? May switch pa ba for drl? Di ba dapat auto on na after magstart? Thanks
    Feb 2011
    sulit ba yung Jump from J to E?
    Quote Originally Posted by chyll2 View Post
    power windows and locks are the only non-negotiable items for me.
    if the J has it, then i'm fine with the J.
    Apr 2006
    The reason why we chose E over J is because of A/T tranny which J does not have. If you are fine with M/T then go for J.
    Jun 2013
    Quote Originally Posted by vyn300d View Post
    just bought the 2017 innova V 2 weeks ago. it doesn't have DRL, though it has an auto setting on the headlights... if this is what you meant.
    Jan 2016
    Question lang. i used fully synthetic oil and its now halfway of the 10,000 km suggested lifespan. Do i need to change just the oil filter or sabay na sa oil change?
    Sep 2012
    Quote Originally Posted by watarii View Post
    If gamit mo oem oil filter much better to replace it, the oem filter is not designed for extended change oil interval (10,000km).
    Jan 2016
    Casa sya i guess oem. My friend said hindi nya ginagawa yan kasi mawawala daw pressure? Is it true?
    walang pressure kapag patay ang engine. so, hindi siya mawawalan dahil walang puedeng mawala.
    ano naman ba ang naka-saad sa owner's manual?
    Jun 2005
    ^anong pressure sinasabi ng kaibigan mo???
    Jan 2016
    He believes na may pressure sa loob ng engine at pag pinalitan filter dapat pati oil na
    Jan 2016
    Well ok kung not true yan, hindi ba sayang lang kung palitan filter kasi full synthetic naman at mas malinis? Reason i brought this up sabi sakin ng sales agent no need na. Service adviser naman dapat daw palitan unless sobrang busy ako. So in short iba iba naririnig ko
    Jan 2016
    Thanks for the replies guys i personally came here na lang to toyota q av. Kailangan daw talaga palitan oil filter at 5k km of use even if hindi pa due oil change
2016 Toyota Innova
