Balak ko na sana palitan brake pads ko kasi nag ssqueak na everytime i brake. can you recommend a durable and affordable na brake pads? or should I get na lang toyota genuine na brake pads?
Of course oem toyota if you have the budget, but bendix general ct is a good replacement also kung medyo nagtitipid.
Bendix General CT will be enough for a Corolla. Costs around 600 if I recall. On my Toyota I use Bendix Metal kings. Around 1200 for a set.
Fuji auto supply, 109 kamias road q.c. Owned by a Tsikoteer now living in Canada but still managed by his cousin ronald![]()
ok thanks bendix na lang kukunin ko instead of the oem sobrang mahal kasi. how much ang labor ngayon for brake pads?
Hope you don't always apply the "cheaper the better" adage on all parts though. 2K+ is still a very good price for OEM brake pads, but nonetheless, Bendix is okay for the daily drive. If you drive on the highway a lot though, i still find the OEM pads better than the Bendix CTs (more consistent feel/bite); if i go Bendix i always opt for the dusty Metal Kings which have very good performance.
You may want to flush, and replace your brake fluid as well when you change your brake pads.
You may want to flush, and replace your brake fluid as well when you change your brake pads.![]()
