Nga kaibigan, 3 beses na ako nasisiraan ng fuse para sa Phone Car charger. Ano po ba ang maganda na gawin? Nagtry na po ako ng brand na elevo, cdr-king kaso lagi nauuwi sa nasisira.
strange...
you can check the fuse used. it might be "sub-standard", that is, it may have a rating lower than what is listed down.
check also if the fuse box heats up..
if that fails, you might have to open 'er up..
strange...
In those instances that I had to replace the fuse, I sought assistance from casa. Should I put in a fuse with higher volts? Wouldnt that make things worse? By the way, thank you for the response, mate!![]()
Sir ano sabi sa casa? Ni-test ba nila? Ako 2 times naputukan ng fuse. Dun sa pangatlo, iniwasan ko yun mga more than 1A rated at two port charger and gumana sya. Kaya ayun, nung bumili ko portable compressor, takot ako iplug dun. Tingin ko low ratings na fuse nakalagay sa mga naunang nasira. Sa next PMS ko, papatest ko sa kanila yun compressor kung gagana pati mga unang charger na binili ko
Normally, Cig lighter ports can accommodate only up to 10A max. What is the label rating on the port's cap (cover)? Mine says "12V 10A max". I am assuming it's pretty standard across all makes.
can't be.. 2.1 milliamperes is too small for anything except standby mode.
at any rate, if the fuse is not sub-spec, perhaps it is time to explore "poor wiring" as cause for fuse blow-out.. as in, something shorts when the charger port is used..
gud pm. newbie here. ask lang ano po ba mag magandang gamitin premium o unleaded?
any will do sir basta pasok sa octane rating ng wigo mo, check mo na lang sa manual kung ano ang recommended octane para sa wigo
i have been using the cheapest unleaded i can find, since day 1 of my wigo. ok naman.
the owner's manual mentions the lowest octane rating the engine will safely run on. 89 or 90 yata..
my answer to this is if you are going to do long drives get the premium. if city driving, regular will do.
Sorry not sure. But it's probably on the cig port cover. Isn't it? I agree with dr.d, maybe have it checked for short circuit. Your car might catch fire if that is not ruled out.
I took my one year old Wigo for a quick run on the tracks last Friday, Clark International Speedway. Toyota sponsored trackday FTW! :D :D :D
sa mga owners ng wigo, kamusta suspension niyo? may nagpalit na ba sa inyo ng shocks, ball joints or stab links? thanks.
