Page 52 of 59 FirstFirst ... 242484950515253545556 ... LastLast
Results 1,021 to 1,040 of 2033
    Jun 2015
    Quote Originally Posted by joseph02091985 View Post
    tama po ba yung sukat ng km per lt sa dash board ng wigo naten?
    It is pretty accurate on my unit. I reset it, and the trip display, every time I fill up the tank.
    Oct 2015
    Hi guys,
    Medyo iba problem ko sa Wigo ngayon. Yung radio smart dial ko (kung saan nagse-save ng station) is nagrereset randomly.
    I always turn off the radio before turning off the car engine pero sometimes after I turn on the engine biglang mag turn on din yung radio and to find out na nagreset nga siya.
    Anyone with the same issue or alam niyo ba cause? :'(
    Thanks!
    Quote Originally Posted by hirano View Post
    Hi guys,
    Thanks!
    it happens in mine, once in a while. nakaka-inis nga. i have to re-set all them favorite stations.
    it does not seem to matter whether i leave the radio on or off, when i start the engine.
    i think that the current going to the radio is diverted to the starter. memory erased!
    is it because our battery is so small?
    btw..
    when i click open the rear hatch, then go out and close the door, the hatch re-closes!
    the air is pushed by the closing door, momentarily pushing out the hatch, which then slams back and re-closes the latch.
    but if i gently close the door with my fingers, or i keep a window open, the hatch does not re-close as often.
    Di ko naman naeexperience pa yan so far sa radio ng Wigo namin ni misis. Will have our 1k PMS on Wed. sa Toyota Pasig since may free oil kami dun hehehe.
    Rant mode lang. Last Sat. we attending a wedding, and the reception was at the Wack Wack Country Club. Somehow may nakabukas ng kotse. Buti nothing major lost since may nakilagay ng bag sa back seat. Just lost a power bank, lightning cable, and a small pouch of coins. Lahat nun nakalagay sa glove compartment.
    Windows and doors were locked naman. Since if naiwan ko na unlocked yun, the light inside would be left open since naka set siya sa door. Asking the guards didn't do any good since nagturuan sila. Pinasadiyos nalang namin and karma nalang bahala.
    Jun 2007
    Quick question: how much is the expected cost for the 1st (1,000km) PMS service? For the 2nd (5,000km)?
    Jun 2015
    Quote Originally Posted by h3lios View Post
    1,000 and 5,000 kms PMS shouldn't cost more than 2K. Free labor pa kasi, and dapat change oil and oil filter plus miscellaneous charges lang.
    Apr 2010
    instead of today, next week pa namin makukuha yung Wigo yung friend ko. may konting problema lang between Toyota Shaw and Toyota Cubao.
    ako pa ang mas excited makuha yung Wigo ng friend ko even though hindi akin yung sasakyan :bwahaha:
    Jan 2016
    mga bro, a pleasant day. newbie here in my wigo. i just want to ask if my trusted online seller sa mga accessories sa wigo because im from negros and mostly no stocks. hope you can help. thanks a lot!
    Apr 2012
    Sa naghahanap ng unit pm niyo ako tulungan ko kayo
    Apr 2010
    agent ka ng toyota?
    Jan 2016
    May tanong lang po ako sa Wigo A/T. Tuwing kelan ko po gagamitin yung d4, 3 and 2? Usually kasi d4 ang gamit ko pag dito dito lang. Thank you.
    Quote Originally Posted by pat0026 View Post
    for 99.99% of the driving experience, d4 is fine.
    d3 and d2 are used, when you need to have higher rpm but do not want not higher speed. 3 and 2 refer to the maximum shift ratios the trans will do. sa tagalog, hanggang tercera o segunda lang, despite higher rpm. these are called upon, when there is high water and we do not want water to enter the tailpipe.. when going up a steep ramp.. , etc..
    only once have i tried it.. and that was because i wanted to see what would happen.
    Jan 2016
    D4 is recommended for normal driving. 3 is position for engine braking while 2 is position for maximum engine braking. for more info, u can check it to your owners manual.
    Nov 2015
    hi... nakuha ko wigo ko Nov 14 2015..hanggang ngyn wala pa ring plate number... yung nakakuha ng wigo po ng nov 2015 same po ba tyo na wala pa ring plate number?thanks
    Oct 2009
    Got ours on Oct 27, 2015. Nahold ng coa ang mga plates during nov at dec. Will still need to check with our sa on the status. Nakakalimutan lang namin magcheck this month.
    Nov 2015
    thanks sa info
    Jan 2016
    Hi guys, wanna ask your expert advise. First time car buyer here for wigo g a/t. Approved na ko sa bank loan and my SA quoted me, 90kdp, 10931/mo. Included na lahat. Gsto ko lng makasigurado na hndi msyadong overprice, and a good deal na din knowing na hard earned money to. Thanks in advance!
    Jun 2015
    Quote Originally Posted by mikeeslava View Post
    Huh. That's odd. I would understand that sort of pricing if it's 2014 and the Wigo is still fresh outta the oven. That's no longer the case now. I just saw someone post sa group that his SA offered to give him a Wigo G AT for 49K DP 10K per month.
    Jun 2005
    5 years to pay ba yan? Over 200k interest ah!
    Dec 2008
    Mga sir ask lang po anyone who installed aftermarket Nav package papano buksan yung headunit hehehe tia
2014 Toyota Wigo
