Guys tinatry ko gamitin na lang SD card (32GB Class 4) para sa music player..pero di sya nababasa. Any ideas? Ok nmn pag USB nakasaksak.
The new look on the cluster is simply using the existing cluster with custom PCB board to accommodate more LEDs points. The cluster will now lights up during the day and dimmed for comfort at night. As for the seatbelt indicator a simple switch is made for the driver's side buckle and extra wiring for the ajar doors indicator as well.
hello guys - need your help. I need to replace one side mirror ng Wigo ko (passenger side). As in replace, not repair. May alam ba kayo kung saan ako makakabili? For temporary use lang naman while waiting for the original part (side mirror from Toyota) to be delivered. Yun lang ang problem sa wigo, wala pang available na part sa casa.
If sa banawe, may mare-recommend ba kayo na store?
Appreciate any help, thanks!
the wigo (aygo, etc..) has been in production for some time now, outside the country. your best bet is probably the katay centers in evangelista and banawe.. sorry but i don't have any definite names to give.
another possibility is, if you have kakilalas frequently going to asean countries, you might ask them to buy you one there..
last, you might try installing a curved rear view mirror over the stock rear view, to partially remedy your blindness..
May I ask what the realistic Fuel consumption of a Wigo AT?
Its seems that there is a wide variations on fuel consumption.
The 3 most important aspects are:
1. Must be automatic
2. Must be very fuel efficient in the City
3. Cost of ownership is low.
Thank you.![]()
Yes sir, that's what I use on mine
https://www.facebook.com/groups/wigoPH/
Drill type or screw type reverse camera? Which is better?
Posted via Tsikot Mobile App
guys question lang tlga bang mababaw lang ang clutch ng wigo? i have an E variant nahihirapan kasi ako pag nirerelease ko ung clutch parang kelangan nakabomba ng husto ung gas para lang ndi mamatay pag naka primera... may iba pa bang nakakaranas nito?
i was responding to joel's query regarding his MT wigo. i explained that my feet were banging into each other as i manipulated the three pedals that the MT unit that i test-drove, had. i further wondered and wished that the AT, having one less pedal, and knowing that only the right foot is needed to drive a regular AT, my feet wouldn't bump into each other anymore.
i haven't test-driven a wigo AT yet...
errr... you use your left foot to drive an AT? are you in the philippines, sir? RHD? modified...?
