Results 2,031 to 2,040 of 2050
- 54,271
November 8th, 2019 09:01 AM #2031
November 8th, 2019 10:47 AM #2033
10W40 is equal to 10W30 in a winter environment. However, 10W30 is better than 10W40 in a non winter environment
Thinner oil is more fuel efficient than thicker oil because the fluid or oil in itself offer resistance. Resistance is overcome by spending energy and the manifestation of energy is heat. Using thin oil offer less resistance, hence the engine need to burn less fuel to overcome that resistance and the engine is subjected to less heat.
The magnitude of saving is a function of time. On the onset its small, but in the long run it will be significant
November 8th, 2019 10:51 AM #2034
- 54,271
January 13th, 2020 04:14 PM #2035ever since new, my wigo's stock radio would, from time to time, need resetting.
the memory would, in-explicably, get erased upon starting.
battery is new.
any ideas, folks?
- Apr 2017
- 21
January 31st, 2020 04:53 PM #2036
- 54,271
February 1st, 2020 12:39 AM #2037
February 1st, 2020 01:52 AM #2038
February 1st, 2020 02:24 AM #2039
Most head units have 2 power input connections tapped to a 12 volt source. The MEMORY wire to a constant source of power (on at all times, even when the ignition switch is in off position)....And, the 'ignition' wire to a power source that's controlled by the ignition switch, therefore will only turn on when the ignition switch is in either the 'on' or 'acc' position.
Have the MEMORY connection checked, doc.
- Feb 2020
- 10
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
