Page 162 of 205 FirstFirst ... 62112152158159160161162163164165166172 ... LastLast
Results 1,611 to 1,620 of 2050
    #1611
    Thanks for sharing the SNY Customs... Will definitely check their stuff out
    #1612
    Quote Originally Posted by myas110 View Post
    siyempre ako naman, I can't blame my friend because nung sinabi sa kanya na nagkataon na walang stock na Black Wigo G A/t doon sa Toyota Shaw at pinalipat siya sa Toyota Cubao na kung saan meron doong stock na black Wigo G A/t. Of course may trabaho din ang kaibigan ko and she is only available on Saturday kung saan wala siyang work. of course hindi naman ako ang magaasikaso niyan unless my friend accompanies me and will tell me na ako na ang bahala sa pagkuha ng sasakyan (and something is fishy going on, like delaying giving the DP from one dealer to another). I am reminding my friend na i-follow up kung ano ang status ng kanyang sasakyan at kung OK na siya.
    and of course, my friend will not shell out another downpayment (mahirap kumuha ng malaking pera at hindi mayaman ang kaibigan ko) para lang makuha agad yung sasakyan sa Toyota Cubao (as what I have posted earlier, my friend was given an option by Toyota cubao to shell out another set of downpayment for the Wigo while waiting for a refund from Shaw, which she declined. She insisted na si Shaw na lang ang magbigay ng DP na pinambayad ng friend ko sa Toyota Shaw kay Cubao). mas OK na maging smooth ang pagbibigay ng DP ng Toyota Shaw sa Toyota Cubao.
    one possible course of action, is to get a unit that is already on stock in the casa, even as it is of a different color. there should be no waiting for that one, eh?
    Apr 2010
    #1613
    well, it's either black or gray metallic lang ang gusto niyang kulay ng Wigo na kukunin niya, nothing else.
    Apr 2010
    #1614
    nakausap ko na yung Sales Manager ng SA na kausap namin sa Toyota Shaw.
    follow-up niya yung refund (nasa accounting na yung check, which is hindi pa daw napipirmahan ng President nila, baka bukas pa, and baka sa Friday pa makukuha.)
    another option is, while in the process pa yung refund, hanap daw siya ng unit sa Toyota Pasig, which is their sister company (subject to availability) kung wala, refund na lang at hanap na lang ng ibang dealer, which is hassle kasi check pa yung pambayad ng kaibigan ko as DP and is subject to clearing pa.
    Apr 2012
    #1615
    Sa naghahanap ng unit pm niyo ako tulungan ko kayo
    Apr 2010
    #1616
    agent ka ng toyota?
    Jan 2016
    #1617
    May tanong lang po ako sa Wigo A/T. Tuwing kelan ko po gagamitin yung d4, 3 and 2? Usually kasi d4 ang gamit ko pag dito dito lang. Thank you.
    #1618
    Quote Originally Posted by pat0026 View Post
    for 99.99% of the driving experience, d4 is fine.
    d3 and d2 are used, when you need to have higher rpm but do not want not higher speed. 3 and 2 refer to the maximum shift ratios the trans will do. sa tagalog, hanggang tercera o segunda lang, despite higher rpm. these are called upon, when there is high water and we do not want water to enter the tailpipe.. when going up a steep ramp.. , etc..
    only once have i tried it.. and that was because i wanted to see what would happen.
    Nov 2015
    #1619
    hi... nakuha ko wigo ko Nov 14 2015..hanggang ngyn wala pa ring plate number... yung nakakuha ng wigo po ng nov 2015 same po ba tyo na wala pa ring plate number?thanks
    Oct 2009
    #1620
    Try mo paps sa toyota makati. Try mo rin hanapin sa fb si jenill garing.
2014 Toyota Wigo
