Results 1 to 4 of 4
    Mar 2011
    Hi Sirs,
    may katanungan lang po ako tungkol sa brake and clutch fluid bakit kaya ganon nung tiningnan ko ung color nang fluid kulay brown siya ano kaya ibig sabihin nun diba dapat kulay puti un
    any suggestion lang po
    regards;
    Roland
    Jan 2011
    Sa brake master naman pwedeng nangaling sa brake piston ng break drum dahil sa rust, maganda pa overhaul mo yung break drums palit ka rubber cap and then ibleed, sa clutch master try mo lang ibleed din sir para malinis, posible din mix brand din brake fluid kaya ganun
    Jun 2011
    Quote Originally Posted by lands_drock View Post
    Hi Sirs,
    regards;
    Roland
    the dot 3 and dot 4 brake fluid are hygroscopic or has a tendency to absorb moisture from the air. it has to be replaced every two years. failure to do so makes the brake fluid contaminated by moisture the brake components get corroded, as a result, the brake fluid changes in color from amber (pilsen beer color) to light or dark brown.
    sa rubber ng mga clutch master cylinders mo yan.sa primary o sa slave. either sa dalawa.
AE101 - Brake and clutch fluid nangingitim
