Results 1 to 6 of 6
July 24th, 2007 05:06 PM #1
Engine specs for Toyota Engine model: 2C-T (2.0 Turbo Diesel)
For 95' Liteace/Townace, 91' Camry
http://img248.imageshack.us/img248/8801/2ct03awl8.png - Camry only Specs
http://img248.imageshack.us/img248/7890/2ct03bri4.png - Liteace only Specs
http://img248.imageshack.us/img248/1174/2ct04azt6.png
http://img248.imageshack.us/img248/6503/2ct04byv0.png
http://img248.imageshack.us/img248/5793/2ct05sz6.pngLast edited by rion; July 24th, 2007 at 05:19 PM.
- Feb 2009
- 1
February 25th, 2009 09:07 AM #2hi....i have a 2000 liteace with 2C-T engine. i can still hear the turbo whine when the tach reaches 1800rpm but the orange led that would signal that the is incoming is now busted.
my problem is with the small pipe (about 3/8" dia.) that feeds the water to the engine block. the inside was thick with plaque (rust+other sediments) so the temp needle would rise from time to time. as there was no replacement pipe available i cut that part off and welded a new one. months later (yesterday), that welded part again is busted.
now, can anybody please point me where i can get hold of a blueprint of this engine to determine the correct part number of my busted part and any part that will have problems in the future?
thank you in advance for any help u can extend.
March 21st, 2009 02:00 AM #3
sorry for the late reply, mas madali sana ito makita under" Engine and Fuel System Talk"
with regards to your Light indicator, kung light bulb lang, I think Madali lang yan Palitan...
for the parts, I have no idea, but you try refference for the 2C from the Tamaraw FX.
- May 2009
- 1
May 15th, 2009 12:37 AM #4
May 15th, 2009 12:57 AM #5
links to the thumbnail seems working...
unfortunately I have not seen any Torque/Power graphs on these engines.
- Jun 2009
- 1
June 9th, 2009 10:37 AM #6where can i buy replacement cylinder head for my Toyota 2C-T (2.0TD) Lite
i would expect something like this, if the authorizing authority did not have a clear idea of their...
Suzuki Fronx
