Results 11 to 20 of 33
November 21st, 2013 03:44 PM #11
Starter motor noisy or excessively rough in engagement
* Starter pinion or flywheel ring gear teeth loose or broken
* Starter motor mounting bolts loose or missing
* Starter motor internal components worn or damaged
Engine starts but stops immediately
* Insufficient fuel reaching the fuel system
* Loose or faulty electrical connections in the ignition circuit
* Vacuum leak at the carburettor/throttle housing or inlet manifold
* Blocked carburettor jet(s) or internal passages
* Fuel injection system faulty
Engine idles erratically
* Incorrectly adjusted idle speed and/or mixture settings
* Air filter element clogged
* Vacuum leak at the carburettor, inlet manifold or associated hoses - carburettor models
* Vacuum leak at the throttle housing, surge tank, inlet manifold or associated hoses - fuel injected models
* Worn, faulty or incorrectly gapped spark plugs
* Incorrectly adjusted valve clearances - B6 and E Series engines
* Faulty HLA Adjuster(s) - B3 and B5 engines
* Uneven or low cylinder compressions
* Camshaft lobes worn
* Timing belt/chain incorrectly tensioned
Engine misfires at idle speed
* Faulty spark plug HT leads
* Incorrectly adjusted idle mixture settings
* Incorrect ignition timing
* Distributor cap cracked or tracking internally
* Disconnected, leaking or perished crankcase ventilation hoses
November 21st, 2013 04:08 PM #12
Engine misfires throughout the driving speed range
* Carburettor worn or incorrectly adjusted
* Fuel filter choked
* Fuel pump faulty or delivery pressure low
* Fuel tank vent blocked or fuel pipes restricted
* Dirty or incorrectly gapped contact breaker points - pre 1982 models
* Faulty condenser - pre 1982 models
Engine hesitates on acceleration
* Carburettor accelerator pump faulty
Engine stalls
* Throttle positioner/idle-up system (where fitted) incorrectly adjusted
November 21st, 2013 05:30 PM #13
Engine lacks power
* Timing belt/chain incorrectly fitted or tensioned
* Brakes binding
* Clutch slipping
* Automatic transmission fluid level incorrect
Engine backfires
* Ignition timing incorrect
Oil pressure warning light illuminated with engine running
* Low oil level or incorrect grade
* Faulty oil pressure transmitter (sender) unit
* Worn engine bearings and/or oil pump
* High engine operating temperature
* Oil pressure relief valve defective
* Oil pick-up strainer clogged
Engine runs-on after switching off
* Idle speed excessively high
* Faulty fuel cut off solenoid - carburettor models
* Excessive carbon build-up in engine
Engine Noises
Pre-ignition (pinking) or knocking during acceleration or under load
* Incorrect grade of fuel
* Worn or damaged distributor or other ignition system component
Whistling or wheezing noises
* Leaking inlet manifold or carburettor gasket - carburettor models
* Leaking inlet manifold or throttle housing/surge tank gasket - fuel injected models
* Leaking exhaust manifold gasket or pipe to manifold joint
* Leaking vacuum hose
* Blowing cylinder head gasket
Tapping or rattling noises
* Incorrect valve clearances - B6 and E Series engines
* Worn valve gear or camshaft
* Worn timing chain or tensioner - E Series engines
* Ancillary component fault (water pump, alternator, etc.)
Knocking or thumping noises
* Worn big end bearings (regular heavy knockings, perhaps less under load)
* Worn main bearings (rumbling and knocking, perhaps worsening under load)
* Piston slap (most noticeable when cold)
November 21st, 2013 05:50 PM #14
2) Cooling System
Overheating
* Insufficient coolant in the system
* Thermostat faulty
* Radiator core blocked or grille restricted
* Electric cooling fan or thermoswitch faulty
* Pressure cap faulty
* Water pump drivebelt worn, or incorrectly adjusted
* Inaccurate temperature gauge sender unit
* Air lock in cooling system
Overcooling
* Thermostat faulty
External coolant leakage
* Deteriorated or damaged hoses or hose clips
* Radiator core or heater matrix leaking
* Water pump seal leaking
* Boiling due to overheating
* Core plug leaking
Internal coolant leakage
* Leaking cylinder head gasket
* Cracked cylinder head or cylinder bore
Corrosion
* Infrequent draining or flushing
* Incorrect antifreeze mixture or incorrect type
November 21st, 2013 06:01 PM #15
3) Fuel and exhaust system
Excessive fuel consumption
* Air filter element dirty
* Choke mechanism incorrectly adjusted or choke sticking - carburettor models
* Tyres underinflated
Fuel leakage and/or fuel odour
* Damaged or corroded fuel tank, pipes or connections
* Carburettor float chamber flooding
Excessive noise or fumes from exhaust system
* Leaking exhaust system
* Leaking, corroded, or damaged silencers or pipe
* Broken mountings causing body or suspension contactLast edited by jodski; November 21st, 2013 at 06:49 PM. Reason: minor correction
November 21st, 2013 06:50 PM #16
4) Clutch
Pedal travels to floor - no pressure or very little resistance
* Broken clutch cable - cable operated clutch
* Low hydraulic fluid level - hydraulically operated clutch
* Incorrect clutch cable adjustment
* Air in the hydraulic system
* Broken clutch release bearing or fork
* Broken diaphragm spring in clutch pressure plate
Clutch fails to disengage (unable to select gears)
* Incorrect clutch pedal adjustment
* Clutch disk sticking on gearbox input shaft splines
* Clutch disc sticking on flywheel or pressure plate
* Faulty pressure plate assembly
* Gearbox input shaft seized in crankshaft spigot bearing
* Clutch release mechanism worn or incorrectly assembled
Clutch slips (engine speed increases with no increase in vehicle speed)
* Hydraulic fluid level too high
* Clutch disc linings excessively worn
* Clutch disc linings contaminated with oil or grease
* Faulty pressure plate or weak diaphragm spring
Judder as clutch is engaged
* Clutch disc cable sticking or frayed
* Clutch master or opening cylinder piston sticking
* Faulty or distorted pressure plate or diaphragm spring
* Worn or loose gearbox mountings
* Clutch disc hub or gearbox input splines worn
Noise when depressing or releasing clutch pedal
* Worn clutch release bearing
* Worn or dry clutch pedal bushes
* Pressure plate diaphragm spring broken
* Broken clutch disc cushioning springs
November 25th, 2013 01:02 PM #17
5) Manual Gearbox
Noisy in neutral when engine running
* Input shaft bearings worn (noise apparent when clutch pedal released but not when depressed)
* Clutch release bearing worn (noise apparent when clutch pedal depressed less when released)
Noisy in one particular gear
* Worn, damaged or chipped gear teeth
Difficulty engaging gears
* Clutch fault
* Worn or damaged gear linkage
* Incorrectly adjusted gear linkage
* Worn synchronizer units
Jumps out of gear
* Worn selector forks
Vibration
* Lack of oil
* Worn bearings
Lubricant leaks
* Leaking differential output oil seal
* Leaking housing joint
* Leaking input shift oil seal
November 25th, 2013 01:36 PM #18
6) Automatic transmission
Note Due to the complexity of the automatic transmission, it is difficult for the home mechanic to properly diagnose and service this unit. For problems other than the following, the vehicle should be taken to a dealer service department or automatic transmission specialist.
Fluid leakage
* Automatic transmission fluid is usually deep red in colour. Fluid leaks should not be confused with engine oil which can easily be blown onto the transmission by air flow.
* To determine the source of a leak, first remove all the built up dirt and grime from transmission housing and surrounding areas using a degreasing agent or by steam cleaning. Drive the vehicle at a low speed so air flow will not blow the leak from its source. Raise and support the vehicle and determine where the leak is coming from. The following are common areas of leakage
(a) Oil Pan
(b) Dipstick tube
(c) Transmission to oil cooler pipes/unions
Transmission blown or has burned smell
* Transmission fluid low or needs renewal
General gear selection problems
* The following are common problems which may be caused by poorly adjusted linkage:
(a) Engine starting in gears other than Park or Neutral
(b) Indicator on gear selector level pointing to a gear other than the one actually being used
(c) Vehicle moves when in Park or Neutral
(d) Poor gear shift quality or erratic gear changes
Transmission will not downshift (kickdown) with accelerator pedal fully depressed
* Low transmission fluid level
* Incorrect selector mechanism adjustment
* Incorrect kickdown switch adjustment
Engine will not start in any gear, or starts in gears other than Park or Neutral
* Incorrect starter/inhibitor switch adjustment
Transmission slips, shifts roughly, is noisy or has no drive in forward or reverse gears
* There are many problem causes for the above problems, but the home mechanic should be concerned with one possibility - fluid level. Before taking the vehicle to a dealer or transmission specialist, check the fluid level and condition of the fluid. Correct the fluid level as necessary or change the fluid and filter if needed. If the problem persists, professional help will be necessary.
November 26th, 2013 03:59 PM #19
7) Driveshafts
Clicking and knocking noise on turns (at slow speed on full lock)
* Lack of velocity joint lubricant
* Worn outer constant velocity joint
Vibration when accelerating or decelerating
* Worn inner constant velocity joint
* Bent or distorted driveshaft
November 26th, 2013 04:14 PM #20
8) Braking system
Note Before assuming that a brake problem exists, make sure that the tyres are in good condition and correctly inflated, the front wheel alignment is correct and the vehicle is not loaded with weight in an unequal manner
Vehicle pulls to one side under braking
* Worn, defective, damaged, or contaminated front or rear brake pads/shoes on one side
* Seized or partly seized front or rear brake caliper/wheel cylinder piston
* A mixture of brake pad/shoe lining materials fitted between sides
* Brake caliper mounting bolts loose
* Worn or damage steering or suspension components
* Faulty dual proportioning valve
Noise (grinding or high pitched squeal) when brakes applied
* Brake pad or shoe friction lining material worn down to metal backing
* Excessive corrosion of brake disk or drum (May be apparent after the vehicle has been standing for some time)
* Foreign object (stone chipping etc.) trapped between brake disc and splash shield
Excessive brake pedal travel
* Inappropriate rear brake self-adjust mechanism
* Faulty master cylinder
* Air in hydraulic system
* Faulty vacuum servo unit
Brake pedal feels spongy when depressed
* Deteriorated flexible rubber brake hoses
* Master cylinder mounting nuts loose
Excessive brake pedal effort required to stop vehicle
* Disconnected, damaged or insecure brake servo vacuum hose
* Primary or secondary hydraulic circuit failure
* Seized brake caliper or wheel cylinder pistons
* Brake pads or brake shoes incorrectly fitted
* Incorrect grade of brake pads or brake shoes fitted
* Brake pads or brake shoe linings contaminated
Judder felt through brake pedal or steering wheel when braking
* Excessive run-out or distortion of front discs or rear drum/discs
* Brake pad or brake shoe linings worn
* Brake caliper or rear brake backplate mounting bolts loose
* Wear in suspension or steering components or mountings
Brakes binding
* Incorrectly adjusted hand brake mechanism or linkage
Rear wheels locking under normal braking
* Rear brake shoe lining contaminated
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
