Results 1 to 10 of 33
November 5th, 2013 12:03 PM #1
For share lang po with regards to the Maintenance specific to Mazda 323
I'm currently transferring the manual that I have para mas madali mag set ng schedule kaysa looking at the paper
You may or may not agree with the items listed so choose what suits you best. On my part kasi hindi ako agree sa listed na every 10K oil change interval
Basta may free time, I will update this thread
To the mods, kindly transfer this to the proper category kung mali
Thanks
November 5th, 2013 12:04 PM #2
**** Every 250 Miles (400 KM) or Weekly ****
Operations Internally and Externally
- Visually examine the tyre for thread depth and wear or damage
- Check and if necessary adjust tyre pressures
Operations in the engine compartment
- Check the engine oil level
- Check the engine coolant level
- Check the screen washer fluid level
- Check the battery electrolyte level
November 5th, 2013 12:04 PM #3
**** Every 6000 Miles (10,000 KM) or 6 months - whichever comes first ****
In addition to the items listed above, carry out the following
Operations internally and externally
- Check the operation of all lights, indicators, instruments and windshield washer system
- Check the operation of the cooling system
- Check and adjust the headlight beam alignment
- Check the operation of the handbrake
- Check the tightness of the wheel nuts
- Check the brake pedal height and operation
- Check the clutch pedal height and operation
Operations with the car raised and supported
- Renew the engine oil
- Renew the oil filter
- Check the front and rear (as applicable) disc pads for wear
- Visually examine the steering gear linkage and rubber gaiters and check the operation of the steering
- Check the exhaust system for condition, leakage and security
- Check the driveshafts and rubber gaiters
- Check the valve clearances (B6 and all E series engines)
- Check the idling speed and CO content
- Check the condition and tension of the water pump/alternator drivebelt
- Check the power steering fluid level and examine the fluid lines and unions for signs of leakage
- Check the condition of the spark plugs
- Check and adjust the contact breaker points and ignition timing (contact breaker ignition system)
- Check the ignition timing (electronic ignition system)
- Check the condition of the distributor cap and rotor arm
- Check the brake fluid level
- Check the clutch fluid level or cable adjustment (as applicable)
- Check the manual gearbox oil level
November 5th, 2013 12:05 PM #4
**** Every 12,000 Miles (20,000 KM) or 12 months - whichever comes first ****
In addition to the operations listed under the 6,000 miles (10,000 KM) heading, carry out the following
- Check and if necessary adjust the front and read wheel toe setting
- Check the operation of the braking system servo unit
- Check all chassis and body nuts and bolts for tightness
- Visually examine the underbody, wheel arches and body panels for damage
- Visually examine the brake pipes, hoses and unions
- Visually examine the fuel lines for signs of leakage
- Check the rear drum brake shoes for wear
- Check the operation of the front and rear suspension
- Renew the fuel filter (carburettor models)
- Check the carburettor linkages and choke mechanism operations (carburettor models)
- Check the operation of the throttle positioner system (B5 and all E series engined models equipped with manual gearbox)
- Check the operation of the dashpot and throttle position switch (fuel injected models)
- Check the automatic transmission fluid level
- Visually examine the cooling system for leakage
November 5th, 2013 12:06 PM #5
**** Every 24,000 Miles (40,000 KM) or 24 months - whichever comes first ****
In addition to the operations listed in the 12,000 mile service, carry out the following
- Grease the front and rear wheel bearings
- Check the condition of the front suspension balljoints
- Renew the manual gearbox oil
- Drain and flush the cooling system and refill with fresh coolant
- Renew the air filter element
- Check the cylinder head bolts for tightness (B6 and E series engines)
- Check the inlet and exhaust manifold nuts and bolts for tightness
- Renew the fuel filter (fuel injected models)
- Renew the brake fluid
**** Every 60,000 Miles (100,000 KM) ****
- Renew the timing belt (B series engines)
November 5th, 2013 04:24 PM #6
Double check your engine type on this one kasi madami klase B3 engine series na 1.3
Engine and cooling system 323, 1.3 1989 to 1991
Type B3. SOHC 16V Capacity (cm3) / number of cylinders 1324 / 4 Compression ratio / pressure bar 9.4 / ³9.5 Oil pressure bar [3.0 to 4.0] Oil temperature ºC _ Valve clearance - inlet mm 0.30 H Valve clearance - exhaust mm 0.30 H Firing order 1-3-4-2 No 1 cylinder position TBE Thermostat opening temperature ºC 80.5 to 83.5 Radiator cap pressure bar 0.76 to 1.04
Fuel system 323, 1.3 1989 to 1991
Idle speed - manual [auto] rpm 850 to 900 Fast idle speed - manual [auto] rpm 1250 to 1750 CO * idle speed [3000 rpm] % ²0.3 HC * idle speed [3000 rpm] ppm ²200 CO2 * idle speed [3000 rpm] % _ O2 * idle speed [3000 rpm] % _ Carburettor / fuel injection Aisan Type / ref 28-32 2V Downdraught Main jet / needle 97, 162 Injection pressure bar _ Pump pressure bar 0.28 to 0.35 Octane rating RON 91[E 91 RON]
Ignition system 323, 1.3 1989 to 1991
Type Electronic Ignition coil _ Primary resistance ohms 0.77 to 0.95 Ballast resistor ohms _ Voltage - Tmnl 15(+) to earth V _ Distributor _ Points gap (air gap) mm _ Dwell angle º (%) _ Condenser capacity μF _ Rotation _ Ignition timing - basic [static º Crankshaft * rpm 0±1 BTDC * idle V = Vacuum NV = No Vacuum NV Total ignition advance º Crankshaft * rpm _ º Crankshaft * rpm _ º Crankshaft * rpm _ Centrifugal check.
º Crankshaft * rpm0 * 1200 º Crankshaft * rpm 12 to 16 * 2700 º Crankshaft * rpm 16 to 20 * 3600 Vacuum range check mbar 133 to 454 Maximum vacuum advance º Crankshaft 12 to 16 Spark plugs NGK/Champion Type BKR5E, 6E / RC9YC Electrode gap mm 0.70 to 0.80
- Sep 2008
- 744
November 6th, 2013 10:44 AM #8I have a 1992 Mazda 323 1.8L A/T nandito ako sa Australia. Bp5 engine JM0BG10P ang VIN
November 11th, 2013 11:11 AM #9
November 21st, 2013 03:21 PM #10
Fault Diagnosis / Troubleshooting Guide
1) Engine
Engine fails to rotate when attempting to start
* Battery terminal connections loose or corroded
* Battery discharged or faulty
* Broken, loose or disconnected wiring in the starting circuit
* Defective starter solenoid or switch
* Defective starter motor
* Starter pinion or flywheel ring gear teeth loose or broken
* Engine earth strap broken or disconnected
Engine rotates but will not start
* Fuel tank empty
* Battery discharged (engine rotates slowly)
* Ignition components damped or damaged
* Broken, loose or disconnected wiring in the ignition circuit
* Worn, faulty or incorrectly gapped spark plugs
* Choke mechanism sticking, incorrectly adjusted, or faulty - carburettor models
* Dirty or incorrectly gapped contact breaker points - pre 1982 models
* Faulty condenser - pre 1982 models
* Major mechanical failure leg camshaft drive
Engine difficult to start when cold
* Other ignition system fault
* Low cylinder compression
Engine difficult to start when hot
* Air filter element dirty or clogged
* Carburettor float chamber flooding
good. these trucks are taking up too much space they don't fit into normal slots anymore. this...
PH Gov't looking to bring back excise tax for...
