Results 1 to 18 of 18
    pips what do you call the white greaselike thingy na usually nasa loob ng power windows motor, power antenna motors etc.?, usually nakikita ko sya sa may mga plastic gears, and san nakakabili, muka kasing safe sya gamitin at dpa masyado messy.
    tnx po
    May 2005
    silicone grease ata ang tawag dun
    Quote Originally Posted by crichton View Post
    u sure sir? where do u think i can buy that? meron kaya sa ace? tnx
    [SIZE=3]silicone grease is widely used by rc racers. you can get it at hobby shops or get some from a friend who is an rc enthusiast.[/SIZE]
    tnx fafables!!
    merun sa electronic store (yan di kasi gamit sa mga heatsink) at hobby shops like Lil's Futaba.
    Jul 2006
    There are many kinds of grease. Silicone grease works well but some have used white lithium grease, or in another instance if you want a dry lubricant then use powdered graphite.
    Food for thought: http://en.wikipedia.org/wiki/Grease_%28lubricant%29
    San mo pala gagamitin yan salev? :naughty2:
    Quote Originally Posted by mazingerZ View Post
    sa airsoft gun gearbox sir, mukang ito kasi ung pinakasafe ilagay sa loob sir eh
    *wildthing - tnx sir
    *mbeige - nice, very informative
    Dec 2007
    Quote Originally Posted by salev View Post
    log on to acmairsoft.com or acmairsoft.org, filairsoft.com
    Dec 2007
    tnx po
    like Mbeige said, its Lithium Grease.
    aite, peace.
    Jan 2008
    I use Mobil FS (grease, light lubricants, etc.) sa baril, wala din palya. There are lubes specifically designed for guns pero ang mahal. Wilth car lubes you will have a supply for a lifetime.
    Alam mo na dito sa Pinas 'Standard Fixes do not Apply' . We prefer backyard car and gun smithing.
    Dec 2007
    Php349.75 sa Ace Hardware...
    Dec 2008
    I could only surmise that its a "White Lithium Grease" based on your description. Its actualy a liquid form of grease, more lighter/liquid but forms into tacky material once sprayed to subject. Its in a aerosol can and can be purchase at any DIY outlets.
    Very good application for indoor/household, hinges, even car door hinges, for waterproofing and lubricating purposes also. Its clean and does not produce the messy, goeey black greasy thing.
    Feb 2005
    *salev, kung sa airsoft gun mo gagamitin you can use Superlube, pde sa lahat ng parte ng baril mo, even on o-rings!, hth
    Jan 2009
    Quote Originally Posted by wildthing View Post
    That's thermal grease... used between the heat sink and the active device it is cooling to promote positive thermal transfer. It's not for lubrication.
    Apr 2008
    ask ko lang po..ok po ba to gamitin sa pulley ng mga sasakyan kasi yung sa akin tuwing umuulan na babasa ng tubig yung pulley ko, yun umiingay pero after spray wd-40 tahimik na siya. dun ko spray sa pulley mismo ha without hitting sa belt itself.
    tnx po
    I think it's a Lithium-based grease with Teflon. Mas water resistant ito compared to other greases. Ask mo na lang sa ACE Hardware.
    Last edited by jjmd3_787; September 5th, 2009 at 10:41 AM. Reason: tao lang po ...
what do you call this kind of grease?
