thanks for the tips..
anyway i just need where to buy brandnew suzuki every/multicab shock absorbers and shock mounts... if ever na wala brandnew baka pa re-build ko na lang sa zee or cruven.. nakita ko na sa thread tong zee eto din pala yung cruven same lang pala sila ng service..akala ko auto supply to eh..
that is only my concern sa Every.. very high rpm kasi ang engine at high speed and baka pumotok engine block pag matagal na??. 6000rpm at 120kph kaya malakas na sa gaso pag mataas rpm ang takbo pero pag maintain sa 3000rpm to 4000rpm matipid naman kaso 60kph to 80kph lang ang speed
i have changed my rear wheel bearings medyo maganit na eh.. and when i check the bearings ang laki ng mga bearings sa rear talagang designed for heavy loads..next ko naman yung front suspension parts...
btw: i've seen sa ebay.ph may nagbebenta ng suzuki parts taga cabuyao laguna madami din sya SGP parts for zuk kei vans.. di ko pa na try bumili pero mukhang ok naman
lahat naman ng cars eh pollutant as long as it burns fuel pollutant pa din kahit EFI or CRDi engine pa yan kahit LPG still contributes to pollution.. EFI engines deteriorate their ability to control emissions lalo na pag OLD na ang engine and same with others...the only thing is these technology improves the way fuel is burned and make it more efficient...most crdi diesel engines you cannot smell the "stench of diesel" katulad nung amoy ng mga old diesels.. you smell nothing at all and at least you can smell is like burned alcohol instead..
btw: i've already indicated "suzuki every" (others are calling it suzuki scrum)pertaining to these kei vans and not to "every suzuki" also thread title indicates the types of suzuki vans..
ask ko lang kung meron na sumubok ng E10 sa ride natin? pwede ba yun sa atin? ![Google Play Suzuki Super Carry / Every / Bravo / Multicab [Merged]](https://play.google.com/intl/en_us/badges/images/generic/en_badge_web_generic.png)
