I've owned a 1997 Suzuki Esteem m/t and a 2005 Suzuki APV a/t. I currently own a 2013 Suzuki Swift 1.4L a/t.
Was brought up to shut up when I have nothing good to say.
Parang mali yung ginawa ko, binalikan ko na lang ung swift nung tapos na ung 1st pms. May list na binigay nung mga ginawa kuno pro ndi ko nabantayan at all
radz15's screenshot has engine flushing at 1k pms. Guys, would you know if kailangan ba ng engine flushing every change oil? (Sabi sa suzuki manila bay kailangan daw). `Question is regardless of vehicle.
yung shop materials, ito yung mga rugs, sandpaper, etc. kahit sa toyota may ganyang charge.
Normally my allowance ang oil. Kung 3 liters ang recommended pede mag sobra for the lubrication of the oil filter the rest is pwede mo na ibigay sayo but ung iba dealer hindi na nila binibigay ung sobra oil. dito na sila kumikita unless alam ng owner. Mas ok pa ung per liter na oil compare sa nasa drum na sinasalok at stock ng casa na contaminated.
Good day everyone, saan pong casa branch ang pulido mag repair / repaint ng gasgas?
Salamat sa tulong.
Salamat sa tulong.
15k pms cost: 2,250
Change oil only at 16,091 odometer reading. Busy walang time dumaan ng casa [emoji28]
Sent via Tapatalk
I just wanna ask for suggestions where I can buy Suzuki Parts. I am looking for a throttle position sensor (tps) for my 2013 Suzuki Celerio. I was informed by Suzuki Auto Makati that I need to buy the entire throttle assembly, because they don't sell tps as a separate item. A throttle assembly (which includes the tps) costs more than P24,000, which is excessively above my budget. Please let me know if you are aware of a dealer/seller that sells tps as a separate item since it will come out much much cheaper to buy it separately.
Recently repaired a mitsu mirage of my friend. Same symptoms of jerking at reverse. Sudden stalling. No check engine light. Yung lower engine compartment niya meron maraming wires nasira ng daga. Rewiring lang lahat. It is now back to normal. I recommended him to use racumin tracking powder. First pack has killed half a dozen rodents
20 K PMS cost: 6,523
Replace spark plugs
Break Cleaning and applied break paste
Replace air filter
Change oil and oil filter
Replaced the cabin air filter. - mukang need ko mas dalasan pagpalit nito ang sagwa kasi ng itsura nung tinanggal na filter
Sent via Tapatalk
pang problema na nakikita ko sa suzuki parang di standard ang parts and labor cost
