Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 108
    #61
    Quote Originally Posted by tolitz_22 View Post
    1st prob. ko ay ang back door lift back ayaw n mag-hold.
    2nd when running high speed rubber burning smell inside the car kahit 75k ang run distance ng car ko.
    Now, ayaw mag-shift ng manual shifter ko pag running engine, pero pag off-engine mai-shift ko nman. PLS. HELP
    Still under warranty?
    #62
    yespo.
    if the car is still under warranty, bring it to the casa. all these issues are covered by warranty.
    well... maybe not the burning rubber issue, depending on the cause.
    Mar 2018
    #63
    Kwento sakin sa service that the evaporator part of the Celerio will be replaced if it's still under warranty.
    #64
    anything can be replaced, if it is still under warranty.
    be aware po, that not all the car is under the same warranty.
    aircon. battery. radio. tires and other wear and tear items. these may not be covered by the standard car warranty.
    Oct 2018
    #65
    Anyone encountering a slight drop in RPM (resulting in a judder) when slowing down to a halt?
    Started noticing it recently on my two year old MT. Seems to happen only for a brief period after starting the engine.
    Sent from my SM-J106B using Tapatalk
    Oct 2018
    #66
    *shifting: Are you unable to shift while the car is STOPPED with the engine running? How do you get it to move?
    The manual says all gears are forward synchronized. If you're having difficulty shifting while moving, have you attempted rev matching?
    Nov 2018
    #67
    I have a 2010 Suzuki Celerio with more the 55,000kms on it. The front end is vibrating badly so i took it to the shop. The shopguy told me that my front wheel bearings needs to be changed and i looked up in google theres 2 dufferent sets of bearings. Can anybody help me?
    Sent from my LDN-LX2 using Tapatalk
    May 2011
    #68
    Quote Originally Posted by jameslum View Post
    My front wheel bearings needs to be changed and i looked up in google theres 2 dufferent sets of bearings. Can anybody help me?
    How will one be of help if you dont properly identify your chariot and not givi g as much detail of your car's history? Please give as much detail that you can more than what you can give personal information about yourself on facebook
    Nov 2018
    #69
    Quote Originally Posted by mina_nuka View Post
    Oh so sorry. Im new here. Ill try to edit it. Thanks
    #70
    the knowledgeable store guys should be able to give you the right one, with a little question-and-answer with you. many times, puede namang i-exchange yung nabili. just don't install it yet or tear it from the packaging.
    googleing sometimes gets one more confused, because of some models' differences in different markets.
    some folks say there's an ID number on the bearing... but this is visualized only after it is taken out of the car.
    good luck.
    Jan 2013
    #71
    KOYO brand
    Front DAC3562W-10CS51
    Rear DAC2552W-13CS25
    If vibrating badly, check mo muna engine mounts. 3 yun.
    Nov 2018
    #72
    Thank you so much kris_13
    Aug 2018
    #73
    Hi, quick question. The control levers should be illuminated when it's dark, right? I think I pulled/pressed something because the labels on the control levers do not light up anymore. Can't find the answers in the manual either
    Sent from my SM-A530F using Tapatalk
    Oct 2018
    #74
    Quote Originally Posted by iliveinyourcar View Post
    Try mo pihitin yung pang reset ng fuel efficiency computer on the right of the gauges. Pang adjust yun ng brightness ng illumination.
    Aug 2018
    #75
    Quote Originally Posted by cesarborja View Post
    Hmm it didn't work. It only increased the brightness of the instrument panel
    Aug 2017
    #76
    Mag-8 years old na celerio namin, 110,000kms
    In my opinion, the real weakness of the Gen1 celerio is the AC system and the Engine support. Ako mismo nawalan na ng lamig sa aircon at nagpalit na ng AUX fan.
    Other than that the engine is very reliable, no engine related troubles.
    Jan 2013
    #77
    Quote Originally Posted by leoblack9 View Post
    Bumigay rin Rad fan ko. Yung motor lang pinalitan ko worth 2500. DIY lang, di mo mahuhugot ang fan assy dapat bunutin din yung coolant hose kaya sabay palit coolant na rin.
    Oct 2018
    #78
    110k kms. - That's awesome.
    Sa tingin ko ang isang key din sa reliability is yung simplicity. Basic lang yung engine - wala ngang VVT even and yet matipid pa rin.
    Aug 2017
    #79
    Yes, no turbo? No egr? No problems! [emoji38]
    Sent from my Moto C Plus using Tapatalk
    Feb 2019
    #80
    Suzuki Newbie (April 2018 CVT) Nag re reset yung infotainment system. Dinala k s casa for regular PMS. May dinala din daw dun na Ertiga na same problem. Papalitan daw head, since under warranty naman, libre daw.
    Sent from my SM-J400G using Tapatalk
Suzuki CELERIO Problems
