Sir 12vdc do you have a copy of the repair manual for our AC and clutch?ung same print screen that you have posted last time?salamat!
AC airconditioning? The last one i posted was the user manual w/c is included in the vehicle. The parts catalog is available for dL-its too big arnd 1.8gb iso img file. I dont have service manual for APV, but im using JX/JLX since it has the same/similar engine/drivetrain, its available for dL arnd the net. iL try to send you the dL link for the img and vitara SM if its still there.
2-DIN lang pala yan, got mixed up with EIA rack unit which is equivalent to 4U. [emoji16]
JonJon,
Sa Speedyfix ako. Bring your regular replacement parts such as air and oil filters, spark plugs and others.
Did'nt have much much time looking for good shops in the Antipolo-Marikina area
Saan yang speedyfix sir? At kung wala ako dalang mga replacement parts okay lang ba?
^Manda near wack2 try to googmap for exact location. May generic supplies sila, kung oem may runner sila pra bumili sa tindahan. Dala ka na lang ng 4L oil mo(royal purple binebenta nila) at oil filterBaldwin BT223 or cross it on the net kung anu available.
12VDC,
Matagal na silang wala na sa Mandaluyong. Sa San Juan na sila, Seaview corner P. Guevarra. I'll avail of their Royal Purple oils.
JonJon,
Except perhaps for spark plugs, Speedfix has no replacement parts on hand. Suggest to buy the parts first (Olympia) before doing the PMS.
Kung sa shell ako bibili ng oil ano dapat ko piliin duon for 4L? Fully S. na sana ilalagay ko, nasa 30k odo na ako ngayon at gusto ko every 10k na ako, last pms ko is sa suzuki casa mismo.
If sa shell,why not have it oil change there? Around 150 lang ata ang labor?
Gusto ko din kase pa tingin iba hindi lang change oil, pero thanks sa suggestion
If you have the owners manual sir you can check there what is needed to check on a certain kms run.
Sino dito unit nila stock color na burgendy red? Ano nakasulat sa OR nyo na color? Sa akin kase RED lang naka sulat, pa rehistro ako kanina sa lto marikina ayaw tanggapin ng inspector, pubta daw ako kung saan nakasulat yung unang OR.
Pag punta ko sa manila east lto. Yung pinaka birth cirtifacte ng kotse galing mismo sa suzuki eh RED lang talaga nakalagay. So mahirap ipapalit sa records kase ang sinusunid nila eh yung pinaka birth cert nga
O dahil si marikina eh maarte lang? Or mahigpit lang? Na rehistro ko na naman sa manila east kanina. Naha hassle lang ako, pano kung next year pupunta na naman ako sa manila east eh malapit lang lto marikina sa bahay ko.
May pina certified true copy na lang ako kanina na CSR yung pinaka birth cert nya, ewan ko kung uubra ito next year renewal
