Results 1 to 5 of 5
- Aug 2005
- 87
July 30th, 2009 10:11 AM #1Hi all, patulong po sa problem
yung '86 boxtype gsr ko nagwi-wiggle when running at 60kph and above, pati yung steering wheel nagwi-wiggle din, malakas.
pag straight yung daan, umaabot ng 70kph without wiggle, pero once me un-even road or kahit konting lubak lang dun nagwi-wiggle. minsan kahit 40kph lang takbo ko pag me un-even road nagwi-wiggle pa rin.
tires are ok naman, though surplus lang sila, more than a year na rin pero makapal pa.
30psi harap at likod na gulong.
thanks
July 30th, 2009 11:12 AM #2
Front suspension parts mo bro mukhang me tama na. It could be a combination of your tie rods, rack ends, sway bar, balljoints. Have it checked immediately as this could be a dangerous proposition should you continue to drive your car without having your car checked and have the necessary components replaced.
- Jul 2003
- 573
July 30th, 2009 08:42 PM #3all wheels should be properly balanced by your tire shop.
lug nuts must be properly torqued.
July 30th, 2009 08:59 PM #4
i have a hunch na baka tire ang problema. baka oblong na, since surplus sya... check mo muna condition nung tires.
- Aug 2005
- 87
July 31st, 2009 01:31 PM #5i'll have it check today, then update ko later what's the mechanic's findings
