1. the ratio of total passenger weight with the vehicle curb weight. if that ratio is small (you weigh 80 kg, the vehicle weighs 2000 kg) then the effect is negligible.
2. the tyre. a bigger contact area requires less pressure (F = P x A). so the wider the tyre the less is the effect of passenger weight. also, radials flatten more than non-radials and thus increases the area of contact with the pavement more as more weight is added. as the area of contact increases the required air pressure to counteract the added weight decreases.
for me, yes sir, there is a significant increase in pressure when there's a load. And as much as possible, kinin sa an pressure na hindi pa tumakbo iyung auto. Cold air pa rin ang nasa loob, just leave a margin for the pressure when it turns warm/hot temp like on the move.
Well for me it's not really necessary if there would be only two of you inside. Little or no difference regardless of tire size.
Now, if you are fully loaded with passengers then it would be wise to take them off first then fill.
In the case of heavy cargo loads that you can't unload while you fill, like in the case of pick-up trucks, then it would be advisable to set the pressure less 1 or 2 PSi of the recommended rating to relieve the tire sidewalls of too much pressure.
My general rule would be to fill or regulate tire pressure BEFORE putting on any load. Works better for me.
my :twocents:
The only condition for maintaining tire pressure (checking/adjusting/etc) is when the car has been driven a while. The tires get warm, the air inside gets warm, it expands, increases the tire pressure.
That's why on a cold tire if it's at 30psi, once you've driven it the pressure can reach up to +4 psi when it gets warmed up, even more on a really fast run. This is why it's recommended to increase tire pressures when driving faster than a certain speed.
Weight balance is negligible when checking tire pressure. Thing is, just fill it up with more than you need, and adjust it the next morning when the tires are still cold. Instead of, say, 10 seconds worth of air, try 15 or 20 if it doesn't have a gauge.
