Results 21 to 40 of 82
    Sep 2012
    Sa bearings, my take, wag ka kukuha ng surplus. Not worth it sa abala kapag bumigay ulit
    Sent from my Windows Phone 8 using Tapatalk
    Apr 2010
    Posted via Tsikot Mobile App
    Jan 2011
    Sana meron mag reply pero ang pagpalit ng wheel bearing sa Vios lalo na sa harap ay kailangan ba pares or kung ano lang yung maugong kase yung sakin sa kanan lang na driver side ang kelangan na palitan?
    Mar 2004
    A worn out wheel bearing manifests at any speed. Humming sound might be caused by the tires.
    Nov 2013
    Sorry for the confusion. The humming sound i mentioned is noticeable at low speeds as well.
    More prominent when above 60kph.
    Aug 2014
    Need your opinion brothers. My car is nissan sentra 2007 gx model. I have to replace my break pads to original kasi yung bendix na gamit ko hindi maganda for my tires. Then my wheels need bearing replacement I got this quote from a mechanic that works for nissan. All original parts daw toh. Ask ko lng kung tama lng ba yung price. Note lng i hhome service niya yung repair
    "sir gd eve ung wheelbearing sa harap 2,742 po ang isa *2 , ung breakpads po 3,748,ung caliperpin with bushing 839 po ang isa *4 ung wheelbearing assembly 7,185 ang labor ko po 2,500 ang total po lhat 22,273"
    Mar 2015
    Quote Originally Posted by shaq1968 View Post
    Sir it's best po na kayo mag leg work regarding sa prices nang oem parts. May makukunan din naman kayo sa labas nang parts po. Tawag lang kayo sa mga shops in banawe or manila for pricing. Labor po is just ok
    Call up Youngbros (Banawe) and Nisway (Ligaya Dr. near Marcos Highway) for quotes. For replacement bearings, go for NSK or Koyo brands.
    I don't understand why the Bendix pads are "hindi maganda for your tires".
    Baka maingay. Bendix used to be na sobrang ingay. Ewan ko mga new models ngayon.
    The hybrids from bendix are cheap and quiet. Stopping power isnt as good as oe though.
    you might consider getting your bearings ex-casa, sir. you can save at least 50 %..
    and i have had my brake pads replaced by off-the-shelf replacements from banawe.. no difference naman sa performance.
    Jun 2008
    Huh! Sobra mahal naman yata.
    Sep 2016
    sir bat ang mahal ng wheel bearing mo? 400 ung estimate ng mechanic ko ang isa?
    Aug 2014
    Thanks bros. Sa servitek shop kaya mas mura?
    Aug 2015
    makiki ride as I suspect wheel bearing issues, correct me if I am wrong and hoping for your help.
    Yung naririnig ko na sound is parang mga barya/maliliit na bakal na inaalog. parang kalansing, parang tambourine sound in a way. lagi ko syang naririnig kapag nasa parking ako. Might be ung speed tska ung liko ng liko. Hindi sya growling/humming sound, and erratic sya pag high speed/city cruising/stop and go. madalas wala at those speeds. Nanggagaling din sa rear as far as I can tell.
    altis AT 2007 1.6G. Any ideas sirs?
    Aug 2015
    Quote Originally Posted by unmarked View Post
    I couldn't have been more wrong with my initial diagnosis. Lumakas ng lumakas ung tunog and it became apparent that upod na ang brake pads ko at hindi wheel bearing issue (i think dahil sa echo sa parking kaya iba ung tunog) LOL. So I had it replaced sa speedyfix with Bendix pads. That feeling when you solve an issue, ayos!
    Jun 2005
    ^ dapat owner supplied parts na lang.
    Mahal pati labor. Might be better to have servitek do everything na lang
    Sep 2016
    Will it take too long to change wheel bearings? may appointment kasi ako sa isang talyer pero di pa siya tumatawag e 2 weeks na, papalitan nya lahat ng bushings pati mga rubber dumper at wheel bearings., nakakatakot kasi habang nagdridrive ako e umuugong ung front tires. uunahin ko na sanang palitan ung mga bearings habang di pa sya tumatawag
    Quote Originally Posted by huntsman View Post
    Nope. Sandali lang yan. As long as Meron press yin shop na papagawan mo
    Jun 2005
    Hanap ka na lang ng ibang gagawa.
    2 weeks mo na pala inaantay tumawag sila eh tapos wala pa. Hindi ka importante sa kanya pag ganyan. Hanap ka na ibang talyer baka.makatipid ka pa sa labor kung isahang gawa lang
Wheel Bearings
