Results 1 to 11 of 11
    Oct 2005
    hi
    eto nanaman ako hingi ulit tulong.
    My mazda pickup pulls to the right and my rear tires are a bit worn out. I wanted to know does servitek offer free wheel alignment if I buy a pair of kelly tires? Is it more economical to get tires and wheel alignment from different shops? I am bit low on budget somewhere around P5000.00 and was wondering if I can get the "kabig" fixed and buy tires on that budget.
    thanks everyone
    ,prysm
    I don't think so. Free balancing lang. Mga 320 to 360 ang alignment sa Servitek.
    Ang full alignment (all wheels) sa Servitek ay less than 1000.
    Oct 2005
    thanks for the replies.
    Do you guys have any other ideas what might needs replacement if the vehicle pulls to the right?
    I just want to be prepared with the money if incase my car needs more than just a wheel alighnment.
    ,prysm
    Feb 2005
    bring it to zee or cruven para ma diagnose.
    Oct 2005
    ang layo kasi nung cruven sa novaliches eh. pero tumawag na ko sa kanila. For now nag re-research pa lang ako sa mga posting dito kung magkano yung usual nagagastos. baka kasi pag pumunta ako ng cruven kulang naman pala pera ko sayang naman biyahe.
    thanks guys
    Oct 2005
    Here is an update.
    I went to Servitek Libis (blueridge carhaus) to have pickup diagnosed and estimates here are the results.
    For Labor they estimate a total of 3800.00
    For parts
    Upper ball joint - 910 x 2 = 1820
    Lower ball joint - 1470 x 2 = 2940
    shaft link - 1190 x 2 = 2380
    Tie rod inner - = 910
    Tie rod outer - 770
    strut bar bushing - 1120
    total is 9940.00
    It seems there diagnostics are correct because they showed that these stuff had problems, However here are some comments that I was wondering about.
    ball joints = only one side had problems so why replace the other side?
    Tie rod = only the inner Tie rod end had problems so why replace the outer?
    ,prysm
    Oct 2005
    Not really neccessary to replace both sides. Do the prices include labor charges? Try to canvass sa mga auto supply for the parts. Its cheaper that way kasi kadalasan nagpapatong pa sila.
    Aug 2005
    Also if you have time, you can buy your own parts. Mas malaki matitipid mo. Try looking for genuine 555 parts.
    Feb 2005
    definitely mas mura kila toti. imho lang naman
    Oct 2005
    thanks sa mga suggestion guys.
    ano ba ibig sabihin ng 555 parts brand ba yun?
    for the kabig nag DIY na lang ako since wala naman pasok ngayon. wala na ko napapansin na kabig. tapos na repack ko pa yung front bearings.
wheel alignment to fix "kabig"
