Results 1 to 10 of 30
- Oct 2004
- 132
January 27th, 2005 10:55 AM #1Anyone nakaexperience na sa inyo when turning the wheels - i mean full turning the car would make tak-tak-tak-tak sound.
The scenario:
From full stop, full-turned the wheel to the left and begin accelerate then I hear the annoying sound above until mawawala lang if i straighten the wheels and go straight ahead. The faster i turn the noisier.
Ano kaya problema?
January 27th, 2005 11:24 AM #3
CV joints iyan (aka velocity joints). Usually papalitan na iyan, hindi na pwede daanin sa repack.
It's not a very expensive procedure. Aside from the CV, you will also need new boots and axle grease.
- Oct 2004
- 132
- Oct 2004
- 132
January 27th, 2005 12:49 PM #5Well, I'll be damned.. searched/found a similar car with a similar problem..
http://www.startribune.com/stories/432/5194824.html
thanks to otep and BB for the replies and the "keyword" :-D
- Oct 2004
- 132
February 1st, 2005 11:41 AM #7Here's just to give you guys an idea.
2 brake disks reface and installation - 280 each (560) plus 300 labor - P 860.00
2 tie rods repair - 150 each - P 300.00
2 rack end repair - 150 each - P 300.00
2 stabilizer link repair - 150 each - P 300.00
4 upper/lower balljoint repair - 150 each - P 300.00
4 shock abs. refill (front and rear) - 400 each - P 1600.00
2 caliper overhaul (replaced 1 piston) - 150 each - P 300.00
4 cv joints and axle overhaul & repack - 120 each - P 480.00
4 f.w. bearings repack - P 400.00
2 break shoes bonding and adjustment (1 each side) 180 plus 200 labor - P 380.00
1 caliper piston - P 450.00 (not brand new)
1 break fluid - P 60.00
1 axle grease - P 300.00
Total Expenses : P 5330.00
To think na pumunta lang ako para paayos cv joint ko at mag-pa-reface. Heheh.. Anyway, pinapakiramdaman ko pa kung ok gawa nila since Saturday and since they gave me 3 mo. gaurantee. Sabi kc nung mayari nung shop.. try na muna nila i-repair kc sayang naman mga original parts tska mas mura na alternative kaysa sa mga replacements. If problem persists dalhin na lang sa kanila ulit to replace na un joint free labor.
What do you guys think???
OT: Nakakainis talaga ninakawan na naman ako ng side mirror this morning!!! Grrrrr...
February 1st, 2005 01:28 PM #8
I think dapat pinapalitan mo na agad yung CV joint instead of having him do all those services (some of which might have been needed in the first place).
But that's just me.
- Oct 2004
- 132
February 1st, 2005 01:45 PM #9Hmmm.. you think so sir Otep? D rin kc ako ka-confident dun sa solusyon or should i say remedyo. Papakiramdaman ko na lang. Worst case pede mangyari would be masira ng tuluyan un joint and d na makaandar un sasakyan.
Thanks for your opinion.
February 2nd, 2005 03:36 AM #10
Para sakin masokay kung palit na lang agad kaysa sa repair or repack.
Mahirap na kasi pag yan ang bumigay eh..lalo na sa suspension pa yan.
Kami dati naglalagay ng chain lock ng motor or bike. Iba nakita ko literal na kadena at padlock.
