wow!nice info,so what happens if its not alinged?
Well, these dots are properly aligned, the number of balancing weights (tingga) you would need to use would be minimized. Properly mounted tyres limits the RFV or radial force variation. If your tyres have a high RFV, the ride won't be that smooth and the ride won't be that comfortable. Plus, it lessens the effective performance of your car.
Medyo mahaba ang explanation sa RFV eh kaya eto na lang ang link sa Wikepedia, he he he. My apologies: medyo nerdy ang explanation dito.
What is Radial Force Variation?
cool thread, i just had new tires and wheels mounted last weekend, check ko nga kung aligned.
Interesting.....pero these marks has minor effects only for older rims di ba? Kasi naglalagay din naman ng weights to make sure of close to zero centrifugal drift during tire alignment if you fit new tires on old rims.....or maybe siguro dahil luma na rin yung rims kaya yun mismo ang may mga deformity contributing to the offset in centrifugal alignment.
just get a new car..are these tyres correctly installed ?..cannot seem find the dimples on the rims but the yellow dot is aligned to the pito....
[IMG][/IMG]
checked the starex tires which were replaced recently ... air valve was aligned with yellow dot ... tires are thai-made bridgestone dueler h/t 684 with red and yellow dots clearly marked![]()
nahanap ko rin ulit... click me anyway, nung nagpalit yung gf ko yung red ang ginamit... pos nung nagsecond the motion din kuya nya na yun nga raw talaga red... e kung ayun sa yoko e either way, ibig ba sabihin nito, pwedeng i-set sa mga pang-balance nilang machine sa mga servitek, etc. kung uniformity/weight method ang ginawa nilang pagmamatch? may case-to-case basis ba 'to? like kung kailan weight matching ang necessary, kailang uniformity? o as implied sa "click me" e, kailangang unahin muna yung uniformity method at kung wala nga uniformity mark, go to weight? rhetoric na ba?![]()
another one of those informative threads... meron na naman ako bago natutunan from tsikot.com...
*nicolodeon: medyo nalito lang po ako and i want to clarify...
quote ko lang yung content nung link:
"Weight Method
When performing weight match-mounting, the yellow mark on the tire, indicating the point of lightest weight, should be aligned with the valve stem on the wheel assembly, which represents the heaviest weight point of the wheel assembly. After match-mounting by either of the above methods, the tire/wheel assembly can be balanced."
ask ko lang po sana kung yung yellow mark ba is really the heaviest (as you mentioned) or lightest part (as indicated in the link above) of the tire? :question:
reading the entire thread so far, my impression is that the yellow thread seems to indicate the lightest part of the tire which should then be aligned to the valve stem slot on the wheel creating a better off-set using the weighted method.. tama po ba o mali?
:thanx: in advance
edit: salamat din nga po pala dun sa nag-up nitong thread...
I bought Michelin tires a few weeks ago and it seems that walang dots yung mga tires. Does that mean it is nicely balanced already? Are those dots for all brand of tires??
*linyx: not all wheel manufactures put that minuscile dimple. Most OEM/factory wheels mounted on locally manufactured cars do not have this minuscile dimple. in the same manner...
*edl100: not all tyre manufacturers put these dots. in fact, even them known tyre manufacturers e.g. goodyear, michellin etc., don't always put these dots on all of their tyre models. No, it does not mean that it is nicely balanced already. AFAIK, there is no perfectly balanced tyre.I watched a tyre manufacturing last week over a cable channel here at Phnom Penh. Them engineers and "tyre scientist" of their say that there is no such thing as a perfectly balaced and perfectly dimensional tyre.
