Results 1 to 9 of 9
- Aug 2003
- 9,720
August 21st, 2003 05:29 PM #1Hi!
A good day to you all. Napansin ko lang na, at times, whenever i press on the brakes, parang lalo pang bumubilis ang takbo ng kotse; so i end up pressing on it hard -- syempre, lahat ng gamit that's not firmly attached, winds up either on the floor or the windshield B).
Napansin ng mekaniko na di daw balanse ung gulong sa likod(drum brakes, btw)...he even pointed out na di pantay ung kain sa brake pads. Could there be a connection? Pag medyo low speeds naman, la namang problema...
August 21st, 2003 05:48 PM #2
mali ang sabi ng mekaniko.
Kung di pantay ang kain ng gulong, camber ang problema.
Since may break fade ka, it's either of the following.
Warped rotors
Worn-out Pads/Shoes
May leak ang breaks mo
or kailangan ipa bleed mo preno mo.
August 21st, 2003 06:01 PM #3
to isolate if there is a leak, perform a simple test. fill your brake fluid reservoir and after three days, observe mo kung nabawasan. kung may bawas, may leak nga. otherwise, yung mga problems are yung mga inenumerate ni artp.
August 21st, 2003 11:19 PM #4
Parang mahina ang hydrovac ng sasakyan mo. Parang lang ha.
Kasi yung sinasabi mong bumibilis, baka illusion lang yun since feeling mo dapat babagal na dahil nasa preno ka na pero dahil mahina ang hydrovac, your car just freewheels (and goes faster).
Ganun nangyari sa Benz na gamit ko dati, eh. Total hydrovac failure.
- 214
August 22nd, 2003 01:47 AM #5try changing ur brakepads and your brakeshoe.. then check the brake master kit kung may tama na..
September 3rd, 2003 02:42 AM #7
how about kung may squeeking sound pag nag bbreak, san ang problem nun?
September 3rd, 2003 12:25 PM #8
if it emanates from where the brakes are (disk).. then it maybe your pads... baka pudpod na.. kaya metal na yung tumatama...
Xiaomi E-Car
