Results 11 to 20 of 28
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 10th, 2006 09:51 AM #12Speedyfix sa shaw blvd. Use the search function and type in speedyfix, he is a regular poster here and his address and phone number is in his sig.
December 10th, 2006 11:21 AM #13
deathlance, tiga saan ka ba? if you're near San Juan, try mo mechanic-friend ko Si Ray Sarol 09209252290...
text mo siya pa-schedule ka sa kanya.
- Nov 2006
- 299
December 10th, 2006 11:50 AM #14try to lubricate the sliding pin,or check the antirattle clip baka after market yan,or the caliper bracket could be bent,baka pinukpok yan,,to diagnose that probs is,,(if front wheel drive)lift the front vehicle,,start the engine,and shift into gear,slowly and be very careful,kung maingay,,tanggalin mo gulong,,kung maingay pa rin,,try mo tanggalin ang antirattle clip,kung maingay pa rin,,eh bent yung caliper bracket pero kung di na eh palitan mo yung antirattle clip.
December 10th, 2006 01:47 PM #15
Possible 'to, may iaadjust lang dun sa clip nun!
sir baka merun kayu alam na magaling na auto shop, sakit na ng ulo ko dito sa brakes eh
December 10th, 2006 02:27 PM #16
sounds far fetch but did you check your axle bearings? bad or going bad bearings is another cause of this.
December 10th, 2006 02:32 PM #17
- Nov 2006
- 299
December 10th, 2006 02:58 PM #18tama si afrasay,ipacheck mo uli baka sa pin at di sa bolt nilagay ang teflon,,di magtagal maglalock o magsiseize yung caliper mo,ispin mo na lang kung gaano kainit ang mechanical component ng brakes eh puede ka magluto ng beefsteak dyan sa rotor,,sigurado matutunaw ang teflon dyan,kahit antiseize grease panglubricate mo ok na,,
December 10th, 2006 03:03 PM #19
...hmmm..on second thought type ko yan beefsteak without the smell of burning pads :D
- Nov 2006
- 299
December 10th, 2006 03:16 PM #20he he he,,di mo talaga maiwasan ang amoy pag dyan mo niluto sa rotor at nakamarenate pa sa asbestos and brake fluid,,,,he he he.
Daming issue ng SU7:grin:
Xiaomi E-Car
